white powder substance build up from battery - Alfa Romeo Bulletin Board & Forums
Old 05-13-2007, 08:44 PM
Unhappy white powder substance build up from battery
I notice after a couple of weeks of turning on my car that it started to have a white powdery substance on the top of the horn brackets in the engine Bay. I washed it off and removed both horns. A week went buy and it didn't appear there anymore(the car had been started 2 to 3 times). When i went to attach sump grill underneath the car a few weeks later I noticed that the bottom of the sump had this white powdery substance built up on it.
Ive seen this powdery substance around battery terminals.
Just wondering if any body's has had this problem and how and if they fixed it?
my thoughts
- maybe earth wire on car isn't touching bare metal (scratch of paint around this area)
- not a good enough connection between stater motor and battery terminal
Old 05-13-2007, 10:39 PM
Slapbass's Avatar
Is replacing the battery an option?
'82 Spider Veloce - (Megasquirt II V3.0, distributorless EDIS)
Old 05-13-2007, 10:57 PM
the battery is new
Old 05-21-2007, 07:00 PM
Has anybody else had a similar problem...NEED HELP URGENTLY!
any suggestions are welcome.
Old 05-21-2007, 07:03 PM
By the way its a 1968 Series 1 1750 GTV coupe
Old 05-21-2007, 11:52 PM
bob7468's Avatar
Send a message via AIM to bob7468 Send a message via Yahoo to bob7468
Clean all grounds and maybe add another ground wire from engine to frame. Use a dielectric grease at the connections.
ground = earth
Good luck!
1986 Alfa Romeo Spider Veloce. (Honolulu, HI)
1991 Alfa Romeo 164L (Melrose, MA)
Old 11-01-2007, 04:01 PM
I realize this is an old post and you surely took care of it but if it's battery acid corrosion a bit of baking soda and water in a spray bottle will take care of neutralizing it.
Seb.
'74 Spider
San Jose, CA
