bonehead move... - Alfa Romeo Bulletin Board & Forums
Old 05-11-2007, 09:59 AM
bonehead move...
i was strapping up some loose wires under the dash in anticipation of an
autocross, and touched a red live wire to the emergency flasher.
zapped a fuse, but also put the zap on my turn signals.
the right on works, but the left one kind of barely comes on, if at all.
do you think it's the blinker relay (not sure what it's official name is) in the dash? can those be obtained?
any wisdom welcome,
john
1969 Alfa Romeo GTV Series1 U.S. Spec.
Old 05-11-2007, 07:24 PM
bshorey's Avatar
Send a message via AIM to bshorey Send a message via MSN to bshorey Send a message via Yahoo to bshorey
any wisdom welcome,
john
The factory flasher unit is outrageously expensive, well over $100 IIEC. However, it's easily replaced with a standard, off the shelf flasher unit you can get at any auto parts store for under $10. The only thing you have to do is make a small 'Y' adapter so you can plug two ground wires into the single ground spade connecter on the new flasher (the Alfa flasher had two ground leads, for no good reason).
Zip tie the new flasher unit to the steering column and you're done!
bs
Old 05-12-2007, 02:14 PM
thanks a ton, bs.
this helps a lot -- i'll give it a shot.
john
Old 05-12-2007, 04:20 PM
GTV Ham's Avatar
I would recheck your ground connections. Are two bulbs in the rear-left tailight coming on at the same time, causing it to appear dim? Might have to take off the lense cover to really check.
Old 05-13-2007, 03:45 AM
Threealfas's Avatar
Pardon my ignorance but does the US spec 1750 come with a hazzard light switch ?
Phil
1961 MGA 1600 Roadster, British Racing Green
1966 Giulia Sprint GT ,Argento
1970 1750 GTV s2, Verde Olivo Metallica (AR213)
2005 Holden Rodeo LT Crew Cab, Fox Fire Red
{Oo==V==oO}
Previously owned
1983 Ford Laser KB, Beige
1985 Volvo 360 GLT Dark Mettalic Blue
1970 GT Junior stepnose Resprayed Red, Giallo Ochre
1923 Amilcar Sports, rusty
I may only own two ALFAs now, but the handle stays as I am always chasing another one.
Old 05-14-2007, 02:10 PM
thanks guys.
i'll recheck the ground wires. the left seems to be worse than the right for some reason.
yes, the u.s. spec 1750 came with emergency flashers, and they are wired somehow in series with the brake/signal lights. i couldn't get them to work the first time until someone reminded me that i had to connect up the emergency flashers to make everything else work.
john
