engine doesn't stop - Alfa Romeo Bulletin Board & Forums
post #1 of 3 (permalink) Old 04-26-2007, 01:29 PM Thread Starter
engine doesn't stop
Engine starts fine but won't stop when I switch her off. She'll run even if I remove the key from the ignition switch. It's not a question of dieseling. Have to put her in gear and lift the clutch to make her stop.
lazaruslong is offline
post #2 of 3 (permalink) Old 04-26-2007, 02:37 PM
Roadtrip's Avatar
Location: Rapid City SD, Black Hills of South Dakota, Queens NY
Sounds like a bad ignition key switch. Do the gauges die when you turn the key switch off?
John Stewart
74 Spider
91 164S
Roadtrip is offline
post #3 of 3 (permalink) Old 04-26-2007, 10:24 PM
Slapbass's Avatar
Yeah, if the ignition switch is still providing power to the relay switching circuit, then you've got an ignition switch problem... (if applicable)
What model/year Alfa is it?
'82 Spider Veloce - (Megasquirt II V3.0, distributorless EDIS)
Slapbass is offline
