electrical interior light dont light up - Alfa Romeo Bulletin Board & Forums
post #1 of 4 (permalink) Old 09-23-2010, 10:14 AM Thread Starter
I have 1986 alfa graduate inter lights have power but doesn't light up bulbs good . Can anyone help, I grounded the ground on the light but that doesn't help
wgibbon is offline
post #2 of 4 (permalink) Old 09-23-2010, 10:27 AM
1966-2013
Tifosi's Avatar
Have you set the lense covers?
They are a rocking affair with all the way tilted in one direction being off all the time, in the middle is on with the timer in the fusebox, and fully tilted the other way is on all the time.
IIRC, the timer needs to be present (or bypassed as descibed up in the spider subsection somewhere) for the lights to function regardless.
Presuming of course the bulbs are good, the light housings are assembled correctly and the wiring is hooked up properly.
'curtesy lights' or 'curtesy lamps' would prolly yield the most results via the forum search engine here and in the spider subsection.
Darren
as hosted by
Tifosi is offline
post #3 of 4 (permalink) Old 09-23-2010, 12:34 PM Thread Starter
interior light works when tilted one way help:::
Thanks for infomation on tilting light housing both lights work when tilted one way, in the middle nothing and the other way on the tilt, nothing. where is the relay please describe and where can i purchase a new one. thanks for the help walt...
wgibbon is offline
post #4 of 4 (permalink) Old 09-23-2010, 02:58 PM
1966-2013
Tifosi's Avatar
N10 in the schematic below is where the timer goes in your fusebox. You prolly won't have any luck getting a new one (hens teeth and all that) but perhaps someone that's breaking a car in the parts for sale subsection would have a good used one available.
Otherwise, while digging around or wating for one to turn up, you can jumper two terminals as shown in the photograph which effectively bypasses the timer and allows the lights to come on when the door is open and shut off immediately when the door is closed. IOW, they'll act like regular un-timed curtesy lights.
Darren
as hosted by
Tifosi is offline
Replace with
