05-12-2010, 09:17 AM
new member - some info & insight
Hi Everyone, I'm soon to be an Alfa Spider owner and since I'm on ly a bit familiar with these auto's I have a few questions.
I'm looking at an'88 Veloce Spider 89K miles no issues, new interior, tires brakes, decent top, no gearbox issues & new paint. Asking $4200.
Also looking at an '88 Graduate - a few door dings & faded spots on the original red, 1st to 2nd gear grind, no leaks, decent top & tires, some rust under the trunk carpet and is asking $3995 or best offer
I'm not sure what the price range is for these Alfa's & whether or not the gear grind on car 2 is a deal breaker.
Any suggestions would be great.
They both claim nice running & driving cars.
alanpavlic
05-14-2010, 04:17 AM
Alan,
I'd recommend you buy the best condition car you can, particularly since there's only a couple of hundred of dollars between them. You'll easily spend the difference trying to improve/fix the lesser car. When purchasing, I'd consider the following in order of importance: body, top, interior, engine, trans, tires, suspension, exhaust, brakes. Electrical issues fall somewhere in between. I keep them out since you'll likey find nagging issues that you'll either decide to live with, like an inaccurate tach, or spend lots of money to fix.
Since these cars are so inexpensive to purchase, you'll find that even just parts will quickly flip the economics of a car that needs work, but is $1000 less, than a nicely maintained car.
Mileage is not particularly important, and low miles can actually be a bad thing. Brakes, in particular, will freeze with low use. Exhaust systems and even engine components don't like to sit over time.
If you're buying in PA, I'd suggest buying a car that passes inspection, including emissions. Many cars are registered as classics which makes them emissions exempt.
Good luck. Hope that helps.
bob brady
05-14-2010, 05:18 AM
[QUOTE=bobbrady;880687]Alan,
Thanks for all your input and advise...really appreciated. I'm going to pick up the Veloce in a few days and will keep you posted as how I make out.
Thanks again
alan
05-24-2010, 10:05 AM
wow - new home for Spider Veloce
Well, made it back from Richmond with the '88 Spider and after getting lost around DC a 3 1/2 hour trip took over 6!
The Spider ran great with no problems even in hours of stopped traffic & 90 degree weather. I had never driven an Alfa & the last time I had a 2 seater was a TR7 some 30 years ago.....the Alfa is definitely a true sports car in every respect.
Nice car & mechanics are perfect...everything works & shifts smooth thru all gears. Gotta get use to the tight pedal locations but all in all a great car!
Thanks for the advise & hope to make some events & compare notes.
AlanP
11-16-2010, 09:50 AM
I hope to be a Alfa owner soon, my first. I'm looking at the Spider's from around 85-92 and I will use this car about twice a week probably. What is it like to own a Spider - could you shed some light on the maintenance cost / intervals etc.? I plan to buy a spider from around $5K+.
Thanks!
