Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Carburetors & Fuel Injection
Old 07-01-2008, 01:17 PM
Bill77's Avatar
Bill77 Bill77 is offline
Pierburg Fuel Supply Pump with Spica FI.
Greetings.
I am installing a Pierburg fuel supply pump from Centerline into my '77 Spider, replacing what I believe is the original pump. The Spica pump is a rebuilt and "breathed on" unit from Wes Ingram.
Question: Will this new Pierburg pump require a restriction in the fuel return line as described in Roadtrip's excellent Fuel Supply manual for other brands of replacement pumps?
Thanks for any info.
Bill
1977 Spider
2000 Aprilia Mille
Old 07-01-2008, 01:42 PM
JoeCab's Avatar
JoeCab JoeCab is offline
The answer is: each car is a little different, but most don't need to have the restrictor modified with the Pierburg pump.
I installed a Pierburg pump on my '72 GTV (also with Hot Wes Ingram Spica Pump) last month and it worked fine with no modifications to the restrictor.
Old 07-02-2008, 05:17 AM
Bill77's Avatar
Thanks for the quick reply, Joe.
Bill
1977 Spider
2000 Aprilia Mille
Old 07-03-2008, 04:26 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
To know for sure, rig up an inexpensive fuel pressure tester with a $10 direct read fuel pressure gauge from the auto parts store and a "T" fitting. Technically, if the fuel low pressure light is off (and does not come on at all during engine operation), then the pressure is over 7 psi and ok. I like to see more like 10-15 psi, however.
John Stewart
74 Spider
