I discussed this issue this weekend, and the consensus is that it can indeed make sense to synch the carbs on the main circuit (min 300 rpm--probably about 3500), in which case there's really no point in synching on the idle circuit.
On the main circuit, there shouldn't be much difference between the two barrels of each barb. If there are significant differences between the barrels of one carb, there no 'bypass' option other than drilling small holes in a throttle plate (an option I don't really find appealing). But if there really is a difference, there may be other issues, such a worn throttle plates, bent shafts, &c.
Ed
1970 Lancia Fulvia 1,6 HF
