Old 05-29-2008, 12:55 PM
GregTV's Avatar
GregTV GregTV is offline
Fuel Cut-off fuel solenoid problems. Need help!
After a 10 year nap, I got my GTV running pretty well however, it seems to lack power. I think I've isolated the problem to the FCS and maybe the fuel mixture.
I adjust the mixture so that the engine is running and idling smooth, but once I attach the wire to the the FCS the car stalls. Dead. Won't start. Take the wire off and the engine runs great (just lacks power). What does this mean? Also, when adjusting the fuel mixture should the wire be attached or unattached?
Greg
[COLOR="Orange"]1971 GTV. [/COLOR][COLOR="orange"][COLOR="RoyalBlue"]1973 GTV: Sold. [/COLOR][/COLOR][COLOR="Red"]1976 Alfetta GT: Sold[/COLOR]
Old 05-29-2008, 01:13 PM
Alfacliff Alfacliff is offline
probably a bad switch on the fcs. under the spica, 2 wires, 12v to one, the other to the fcs. maybe adjustement.
cliff
Old 05-29-2008, 08:51 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Probably a shorted microswitch. Trace the wire back to the microswitch, then back to the feeder wire on the right side of the engine compartment. Make sure that the microswitch isn't being bypassed and hot current fed directly to the FCS.
If the system is tuned correctly, you can defer replacing the microswitch until a later time when you have the injection pump off the engine anyway.
John Stewart
74 Spider
