Spica microswitch wiring question
I just noticed that there is no hot wire leading to the microswitch/fuel cutoff solenoid on my 74 GTV. No wonder I have backfiring on decel. This likely has been true since I had a shop install a good used pump in the middle of a failed gross-polluter smog check four years ago. That was fun.
Question. Can someone look at a 74 GTV and tell me where the hot wire to the microswitch comes from, and what color it is. I know what's in the wiring diagram, but I'd like to know what's on an actual car. I see no spare hot wire coming to that area from the front as on my Berlina (white wire with black sleeve). However, there is a spare green hot wire coming out of a bundle right by the brake failure switch, near the right rear corner of the engine compt. Maybe I can use that one?
Andrew
