Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Carburetors & Fuel Injection
Old 03-13-2008, 07:23 AM
Andrew Andrew is offline
Don't throw away Spica actuators!
I was just talking to Wes Ingram, who mentioned the need to save Spica thermostatic actuators for rebuilding. There is of course a finite supply of them, and the number of good ones without broken tubes is dwindling. The tube replacement process is not a simple one, something Wes's shop I believe does not currently do, though a guy in LA does, but may not forever.
The point being, don't throw away any actuators, regardless of condition. Wes's shop pays for rebuildable cores, and will also take ones that seem sub-rebuildable, but might be worth fixing as the supply gets lower.
Wes mentioned there is currently no viable alternative to a TA on a Spica car, though I know some folks have tried to come up with digital replacements.
Andrew
Old 03-13-2008, 08:36 AM
jarrington's Avatar
jarrington jarrington is offline
I just turned in a bunch to IAP for store credit, which I imagine will eventually make their way back to Wes or one of the other rebuilders.
-Jason
Jason Arrington
'74 Spider
'67 Super project
'98 M3 Sedan
'04 Mazda TurboCumminsSuperDieselMax MPV (Alfa tow rig)
Old 03-13-2008, 08:52 AM
ossodiseppia's Avatar
What's the going rate for rebuildable cores?
Check out my restoration
Old 03-13-2008, 09:00 AM
$10-15 from Wes.
Andrew
Old 03-13-2008, 02:11 PM
jarrington's Avatar
$40 store credit from IAP.
Selling Cores to IAP
-Jason
Jason Arrington
'74 Spider
'67 Super project
'98 M3 Sedan
Old 03-24-2008, 11:50 AM
lowmileage's Avatar
IAP gets $245 for a replacement with a rebuildable core. Yikes
Old 03-27-2008, 08:35 AM
alfafan61's Avatar
alfafan61 alfafan61 is offline
I still send mine back to WES. Avoid the middle man
Alfafan61
(79 Spider)
Old 03-27-2008, 08:42 AM
lowmileage's Avatar
-Jason
Hmn, lets see now - they will pay you $40 (via store credit) for a rebuildable one yet charge you $100 as a core charge.
Old 03-28-2008, 07:50 AM
usatrade's Avatar
usatrade usatrade is offline
To Andrew
Who is the guy in LA that rebultys those TA's ?
thanks
Claude
P.S. Do any one knows if we can test a TA in hot water like we do with engine/water thermostats ?
Old 03-28-2008, 07:56 AM
Yes, I test my TAs on the stove with a meat thermometer to check the water temp. Boiling is too hot, so you need to stay a bit below it.
I believe it's Robin Hoeven (sp) in Long Beach, who does/did advertize in the Alfa Owner.
Andrew
Old 03-28-2008, 08:01 AM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
Originally Posted by usatrade View Post
To Andrew
thanks
Claude
Check the Supplier List thread. Robin Hoven is listed there.
John Stewart
74 Spider
Old 03-28-2008, 08:05 AM
usatrade's Avatar
Thanks guys,
I am going to soft boil my morning egg in my water TA testing (testing the TA before it boils THEN cook my egg - hopefully not the other way)
Thanks again
Have a fabulous day
Claude
P.S. Who is the BB website manager/master ?
Old 05-15-2008, 08:03 PM
green 69 gtv's Avatar
green 69 gtv green 69 gtv is offline
Andrew
Andrew,
Do you know if my TA extends to the right length when hot but does not retract completely when cool is it time for a rebuild? I believe I read this somewhere (Alfa Owners Bible?).
John
  #14 (permalink)
Old 05-16-2008, 05:06 AM
Roadtrip's Avatar
74 Alfa Spider
A serviceable TA will NOT retract all the way. Retracting all the way into the brass base is one indication that the TA is shot.
The older versions (27mm extension, years 69-76, [T260 Calif]) are very scarce now, but the specs on them are 19mm at room temp and 27mm at 175F (+/-1mm).
The newer versions are 29mm and 31mm extension (+/-1mm) (at 175F, years 76 [T261] -81) with room temp extensions of about 23mm (+/-1mm). When testing, if the hot extension is correct, the cold extension will almost certainly be within spec.
John Stewart
74 Spider
  #15 (permalink)
Old 05-17-2008, 11:40 AM
Oops
Oops you're right. I retested mine just to make sure I was accurate and, in fact, I had things backward. At 170-180F, the plunger only extends about 5mm (measuring from the end of the brass base) and when cool, it retracts all the way and even more (to about minus 1-2mm).
John
Articles
