#16 (permalink)
Old 05-17-2008, 04:32 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
As in the diagram above, the measurement is from the flange (with the screw holes in it) to the tip of the piston with about 4kg of force applied. Your's sounds like it doesn't meet specs.
John Stewart
74 Spider
  #17 (permalink)
Old 05-17-2008, 07:37 PM
green 69 gtv's Avatar
green 69 gtv green 69 gtv is offline
Yes, you are right. I believe I need a minimum of 6 mm of movement from cold to hot and that is all that I was checking. Time for a rebuild. Thanks.
