Old 03-12-2008, 02:45 PM
rafael rafael is offline
dellorto dhla 40 identification
Hello,
I just acquired two pairs of dellorto dhla40 carbs. Both pair are of the dhla40 type without additional character. From what I read this implies that the carbs are of the performance type (hence no emission type). This can be seen from several things:
- the air bleed holes are of the recessed type
- there are less that 5 progression holes.
However, one pair has 3 progression holes, whereas the other pair has 4 progression holes.
Besides that I have a dhla40f pair of carbs, and those are of the emission type (recessed bleed holes and 5 progression holes).
My question is:
how many progression holes should an performance dhla40 carb have? In the book of Des Hammill it is written that it should be 3. However I seem to have a pair with 4 holes....
________________________________________________________
156 2.0 TS 2000 | spider 2.0i 1992 | GTV 2000 1971 (being rebuild)
Old 03-13-2008, 06:11 AM
B4S B4S is offline
From my searching after I bought some 40Hs, I've read that there are Dells with the 4 and 5 progression holes, but no extra character as well as the non-recessed air bleed. They are later model performance carbs, and the extra holes are supposed to provide a bit of extra progression. I'm assuming the holes are quite small, vs. the extra large 5 holes in my Hs.
