Old 02-04-2008, 01:24 PM
ill_will ill_will is offline
cleaning: overnight carb soaking + mixture needles
Hi all,
I'm having some idle circuit problems and am wanting to soak my carb bodies and various jets etc (40DCOE44/45s) overnight to make sure they're clean.
After some searching it seems that people quite often 'soak them overnight', the question is: in what?
I searched for some carb cleaning products, and on the forum (people mentioned products you mix with petrol (gasoline); other people mentioned paint thinners, others pure petrol, etc.) but the only ones I could find here in the u.k. are the fairly ineffectual aerosol ones, which are usually xlene or similar.
Anybody soaked their carbs overnight in thinners/petrol/anything else, and found it actually works? I'd be appreciative of any guidance on this issue.
The other issue is the mixture adjustment needles. I've ruled out vacuum leaks, balanced the carbs, adjusted the mixture using colourtune, done the timing, etc, but am still getting some hesitation at lowish rpm cruise, particularly when trying to gently reapply the throttle, say, when coming up behind slower moving traffic and matching speed with the car in front. The car bounces forward and back, like it's missing on a cylinder (or more.)
Could worn/damaged idle mixture adjustment needles cause this kind of behaviour? or are there any other likely culprits? I've tried switching the idle jets between different cylinders but can't tell if the problem has moved! I have cleanen and serviced the carbs twice, including blowing out the passages with compressed air, to no avail.
will
Old 02-04-2008, 02:03 PM
Tifosi's Avatar
Tifosi Tifosi is offline
Slacker
Kerosene/parrafin or mineral spirits would do you justice for a soak.
The latter a bit more than the former, but both are effective.
Darren
as hosted by
Old 02-05-2008, 03:39 AM
Will that be strong enough? Mineral spirits is a petroleum distillate, right?
Old 02-05-2008, 09:29 AM
pathung's Avatar
pathung pathung is offline
Black is Faster...
Are the progression hole passages clear (blow compressed air through them)? When you're loafing around behind a slow car, the engine's probably turning at less than 2,800 rpm, and the progression circuit (part of idle circuit) would come into play. I'm assuming that the car idles fine, which would rule out (I think) anything being wrong/inappropriate with the idle jets.
The spark plugs and wires are good?
Patrick Hung
'59 Giulietta Sprint * '63 Giulia Spider * '67 GTV
Costa Rica & Taiwan SNO Chapter Director
Vintage Alfa Registers
Old 02-06-2008, 12:28 PM
Patrick,
The holes were ok, i did blow them out, but i'll double check. One thing I have noticed is that the #4 throttle plate is fractionally more open/closed (can't remember which) than the others (looking through the progression holes. Jim K. recommended carefully bending the shaft back so they are perfectly aligned; I'll try this.
All electrical service items are good. Before when the idle was worse I could see the spark firing inside the #4 cylinder but not igniting the mixture (using a colourtune.)
Thanks for the tips - hopefully we'll get to the bottom of this soon!
will
Old 02-06-2008, 02:27 PM
Tifosi's Avatar
Slacker
Have you run a compression check and/or leakdown on that cylinder? (numerous threads describing both process here and there on the board)
Fire but no mixture ignition is a fair sign that your compression isn't where it should be.
Darren
as hosted by
Old 02-06-2008, 04:09 PM
yeah, i did compression tests twice - even 175psi on all cylinders. i'll triple check it once i've straightened out the throttle butterflies and reset everything.
regards
will
Old 02-07-2008, 01:01 AM
Cosmo's Avatar
Cosmo Cosmo is offline
Just a note, as I've made the same mistake myself a couple of times: A compression test must be done at WOT so a slight imbalance in the butterflys won't make a difference to your test.
Cosmo
Spider 1750 Veloce
Jaguar XJR-S
Saab 900 LPT
Old 02-12-2008, 04:48 AM
tomcotez's Avatar
tomcotez tomcotez is offline
What about cocacola? Don't laugh!.. Its supposed to slightly acidic and good for cleaning old coins etc, might that work on a cruddy carburettor?
Old 02-12-2008, 05:28 AM
Rich's Avatar
Rich Rich is offline
Cleaning Carbs
Hi Will,
I will add my two cents. I used carb cleaner from a spray can, by spraying each jet individually and used a a metal container (empty coffee tin with lid) to collect the spray off and drips. Then I emptied the spay can into the tin and soaked all the jets for an hour and then removed them and used compressed air in each jet. The rest of the fluid can be used for cleaning other stuff with an old tooth brush. The carb body was cleaned in my parts washer.
Once assembled i used Kerosene to test.
Rich
Old 02-12-2008, 06:59 AM
Tifosi's Avatar
Slacker
Easier to skip the cola and go straight to conventional solvent/cleaners as you'll be using it to clean off the syrup that got in and gummed up a bunch of stuff afterward anyway. (once the cola starts to evaporate/dry, you might as well be using maple syrup)
Darren
as hosted by
Old 02-13-2008, 11:08 AM
bill2000 bill2000 is offline
Yes, coke has rather a lot of acid in it, but I would think you'd want to clean your carbs with acid. I think you're looking for a solvent for loosen the varnish and crud.
Bill
"Can't this thing go any faster? Ultimate driving machine my a**!"
-Buffy
Old 02-13-2008, 09:55 PM
karmat's Avatar
karmat karmat is offline
Will I know you said you tuned up the mixture with a Colortune and they do work really well. But that problem you're experiencing in my experience is almost always a lean idle mixture (though too rich could cause it). Richen the mixture a bit on all cylinders and go for a test. If it's better, richen slightly more, and test. Could be that simple. If no change at all, then back the mixture out to where it was. Try leaning a step at a time. Test. If that doesn't do anything then it's something else.
If you need to figure out if a single cylinder has a problem, carefully, wearing gloves, pull each spark plug wire one at a time. When you pull each one the idle will slow. If there is one where the idle is less affected that on the others, that's your culprit. Don't leave the wire off for long, and make sure you don't get any body parts between it and a ground. Once you put each wire back on let the car run for 10-12 seconds to let the idle smooth back out (the mixture will be horrible in that cylinder until the extra fuel burns off).
Hopefully that gets you a little further.
Karl
[B]Have:[/B] 1969 1750 GTV under restoration
1969 1750 Berlina
1968 Giulia Sprint GTV (very rough, no motor)
[B]Had:[/B] 1982 GTV6 3.0 w/4.10 rear, Stebro (imported engine from UK in 2002) -- Rear-ended 8/2004.
1988 Milano Verde
[B]Non-Alfas:[/B]1984 Volvo 244
