intermittent fuel pump
Hello to all. This is my first posting.
Recently my '81 spider developed a fuel delivery problem. Turn the key to ON, the low fuel pressure light stays on, and the electric fuel pump under the car is not running. Tried it again a few minutes later and low fuel pressure light flashed and then went out and fuel pump was operating normally. The next day the problem was back and then went away again.
I checked the #1 fuse in the secondary fuse box under the dash. Good fuse and good connection. I checked the contacts at the fuel pump and they are clean and making good contact.
After talking to IAP, my plan is to check for voltage at the fuel pump with the key ON, and also check the inertia switch for continuity. My theory is a failing fuel pump, a bad ground to the fuel pump, or bad/intermittent contacts at the inertia switch.
Here are my questions:
Where on the car is the ground connected from the fuel pump?
Can poor inertia switch contacts cause an intermittent fuel pump?
If the fuel pump is failing, will it work only part of the time?
At this point I don't believe it's a fuel filter problem because the fuel pump is intermittent. Thanks for your input.
jdw
'81 Spider Veloce
