Shanhel Sure Shot
The T/A was designed by SPICA to adhere to US EPA emissions rules. These rules required that an automobile had to go through a cold start, run cycle that met certain emissions requirements, without driver intervention.. The T/A was designed to meet these standards through its gradual leaning of the mixture based on engine coolant temperature. The T/A tends to weaken after time, i.e. it does not extend enough and then does not lean the mixture sufficiently. The Sure Start allows one to lean (or richen) the mixture manually, like a traditional choke. In effect, the Sure Start works like the manual choke on the European carbuerated versions of the car.
