If the CSS is sticking, it's probably not the solenoid but the little plastic hydraulic piston at the bottom.
Loosing the CSS will probably just throw it out of adjustment. In order to remove the solenoid (and not just adjust it) you'll have to remove the very small cotter pin that holds the piston rod. It's really small and is accessed through the rear inspection plate. I'd be pretty impressed if you could get it back in while bent over in the engine compartment and using a hand mirror and needle nose pliers. At any rate, there's really no reason to remove the CSS unless it's burned out and being replaced. The CSS locknut is 24mm. A ground-thin crowsfoot will definately loosen it or you might have luck with some needlenose vice-grips.
Those plastic plunger/pistons at the bottom of the rod have been know to swell slightly and hang up in the bore, which is probably what the problem is. If that's indeed the problem, the perm fix is to remove the pump, take the plunger out and mill it VERY slightly about .002-.003" using a drill to spin it and a fine file. As mentioned above, to remove the plunger/piston, you have to remove the very small cotter pin, then extract the rod+plunger through the bottom of the pump (there's a large what looks like a drain plug at the bottom).
But, before you do that, you might check to see if it's just gunked-up inside there. When was the last time the oil was changed in the logic section? Try removing bottom plug to the plunger/piston bore. Be ready for oil to leak out. Then remove the side inspection plate and spray some WD-40 down on the plunger to clean it out. Disconnect the long rod at the pump rear throttle lever and push the lever to the reference screw stop. It will take a little force to overcome the springs. Reach in and move the plunger rod up and down to see how free it is. You have to hold the throttle lever over on the reference screw in order to move the plunger rod by your finger. If it seems pretty free, you might get away with just a cleaning. If not, then you'll have to remove the pump and fix it on the bench.
Before putting the inspection plate back on however, I'd recommend using a big syringe or turkey baster and hose to suck out the old oil in the bottom of the logic section. When all the inspection plates and bottom plug are back in, remove the baro compensator from the top and pour in about a half pint of clean fresh engine oil. You don't have to worry about overfilling, because there's a drain hole back to the sump to maintain the corrrect level. The logic section is splash lubricated from captured dedicated oil and does not receive oil from the engine.
John Stewart
74 Spider
