For those who'd like a little more background on this discussion:
At idle and low rpms there is almost no difference in the amount of fuel delivered relative to the temp lever position. At high speed and load, there is a significant difference. The reason is that the temp lever allows the compensator link arm to ride a little high on the vertical notched lever. At idle and since the vertical notched lever is straight up, the position of the compensator link is virtually the same regardless of which notch it's in. However, the radius of movement on the vertical notches lever is significantly different between the top of the notches and the lower notches. Hence, why at idle there is no difference in fuel delivery, while at large throttle demand, there's much more proportionally.
Here's a rather crude quick drawing of the relationship of the internal parts. Where it indicates rich and lean next to the Altitude Compensator, you can also use low altitude (rich) and high altitude (lean).
John Stewart
74 Spider
