Well, found a site about the "engine tuning" parts we discussed in a thread in the 75/Milano forum a while back.
I don't want to twist the knife or anything, I just thought this site was hilarious.
Check out all the big words in the first part of the text, quote from SpiralMax homepage(
Homepage link):
"SpiralMax ® is a combination vortex generator, velocity stack, and venturi, made of stainless steel, installed in the air path, that extends the resident time between gas and air, maximizing vaporization for better combustion. It's beneficial for the engine, and is compatible and enhances the performance of all common aftermarket products, it is synergistic."
And it goes on:
"SpiralMax ®, is good for all cars. Besides giving you instant pickup and power, it will clean out and reduce carbon build-up, you will have longer lasting spark plugs, smoother running car, and reduced vibration and engine noise. You get more torque, acceleration, and better fuel economy. How is this done? Through better combustion. It is easy to install and typically takes less than (3) three minutes, do-it-yourself with just basic tools. . . .
Typical range of improvement over baseline is:
0 to 35 increase in horsepower,
0 to 31.85% increase in fuel economy.
(Actual performance may vary, depending on type of car, driver, and actual driving conditions.)"
Fantastic product, I wonder how it reduces vibrations and engine noise... Must be an engine in pretty crappy shape if thats going to happen.
They also have the "Turbo Exhaust Tube";
Link
My advise is that you stay as far away from these products as humanly possible...
