Old 10-21-2003, 11:45 AM
pauldyworth pauldyworth is offline
cam/carb combination
Only just found this site - wow what a great source of information!
Anyway hi everyone, I have a 72 European Spider which requires the engine to be rebuilt. I therefore am looking at this as an opportunity to possibily uprate it. Presently it runs on Dellorto 40's and the standard European cams. My query is if I keep the 40's, should I run an 11mm cam, or could I get away with a 12mm one, or should I be looking to change to 45's if I run a 12mm cam?
Old 10-21-2003, 04:03 PM
GTV4EVR's Avatar
GTV4EVR GTV4EVR is offline
No personal experiance, but I am trying to make the same decision for next year's rebuild. Kevin at EB Spares in England tells me that you need the 45s to take advantage of the 12mm cams he sells (Colombo).
Ken Lee
Oakville, ON
1973 GTV 2000 - Rowdy (or this one I hope)
Old 10-21-2003, 04:05 PM
GTV4EVR's Avatar
Is this easier to see?
Ken Lee
Oakville, ON
Old 10-21-2003, 05:24 PM
genericwood's Avatar
genericwood genericwood is offline
No personal experience with running Dellortos and 12mm cams. But I can tell you Wes Ingram (Spica Guru) says a modified pump with 40mm throttle bodies can benefit from the 12mm cams. I would be surprised if you couldn't get some benefit from the extra lift with the Dellortos. But I'm sure you would get even more with the 45's.
Erik
Old 10-21-2003, 05:49 PM
papajam's Avatar
papajam papajam is offline
with the Librarian
Welcome to the Board, pauldyworth!
Keep in mind that it's not the barrel size (40 vs. 45) that lets the engine breathe; it's the choke (venturi) size. There's a good writeup on choke/barrel selection here and although it's based on the Weber DCOE, I'd think the pricipals would be the same for Dellorto. It basically boils down to at what RPM is peak power produced.
Series 1 Euro 1750 GTV
Series 2 US 1750 GTV
Series 3 Spider Veloce
Old 10-23-2003, 07:44 AM
emr5503 emr5503 is offline
Link
Unable to connect to your referenced site. Do you have to be an AOL user?
Old 10-23-2003, 06:39 PM
papajam's Avatar
with the Librarian
emr5503,
Try this. http://members.aol.com/_ht_a/Dvandrews/webers.htm
Old 10-23-2003, 06:45 PM
Thanks for trying again !
Guess AOL & Mozilla are still at war.
Ed
Old 10-23-2003, 07:02 PM
papajam's Avatar
with the Librarian
Would you want me to scan and email it? Would take a day or two.
Old 10-23-2003, 07:12 PM
Jase Jase is offline
If you wait 5 minutes, I'll mirror it for you...
Jason
1973 2000 GTV
Old 10-23-2003, 07:17 PM
try this...
http://www.westerngeo.com.au/alfa/carbs.zip
1973 2000 GTV
Old 10-23-2003, 07:22 PM
Doc.
Thank you !!!
Ed
