Jim -
Dummy Thermo Actuator Tool A40166: 27.8 mm
(Same as on the 75-76 "All Models", and the 77 "Non-Calif Models")
Cold Protrusion 23mm (+/- 1mm) @ 68F. Closer to 22mm for cold climates and 24mm for warm ones. Shim to achieve, if necessary. Proper "cold" calibration aids cold starting.
Hot Protrusion 29mm (+/- 1mm) at 176F and 31mm (+/- 1.5mm) with the engine hot. With engine hot, pump gap should be .019" or less. The mixture does not change at pump gaps less than .019."
The 81's have are the "MONOFARFALLA" variant with the single throat butterfly plus almost every power-robbing, Rube-Goldberg, anti-pollution device ever invented. I've never actually seen one, but they do have a different idle adjustment, etc. It also has a anti-tamper brass cap over the cam centering screw, most of which are probably long-since removed by now.
I have the Factory "Set-up Procedures and Adjustment, 1980-1981 Manual." It's six pages.
PM me you FAX number and I can FAX it to you.
John Stewart
74 Spider
