01-02-2007, 02:14 PM
Here's the set-up on my Alfetta racer. I designed the intake system myself and had a machinist friend of mine make them. He does excellent work (makes all the items for my hobby company: ultra hobby products).
The tubes are 3.5" long, have a 5 degree taper, and the ends are threaded and the nurled cap screws on so a filter, screen, or both can be put in place. I have been very happy with the system. Especially the way it looks and sounds.
I do offer them for sale thru my website at: www.egpworld.com/ultrahobby. Note: I am still trying to get my web guy to correct the spelling; he knows less than nothing about cars.
Thanks, Steve
ultrahobbyproducts.com: Accessories, plans, and kits for CL and RC model aircraft.
02-17-2007, 04:32 PM
Sebring winning 66 GTA
Originally Posted by Azzurri GTV
Wow, do you have any more pics?
Steve, would you please share Sebring winning GTA pictures with us for hist. library in Austria. Thank you, Joe awaw911@aol.com
03-12-2007, 07:46 PM
where did you get them
Where did you get those horns? they look to be of nice quality!
03-12-2007, 07:59 PM
Slacker
Might not be the source he used, but there's quite a few varities that can be found here if you look through thier spec/size sheets.
03-13-2007, 06:19 AM
thanks!
Thanks for the info. Now I have to find a cold air box that costs less than $300!
02-19-2008, 10:12 PM
Reviving a old thread as I am doing some research to make a decision for a racing intake.
"I've found that height above the stacks is pretty important".
This has been mentioned to me before and a experienced racer related that I should use my Shankle sport Carb conversion kit on my exisitng Spica intake(instead of the euro intake manifold) due to the extra inch the plates that fit between the Spica intake and the carburetors. He said that the intake flow benefits and as a result will transalte into more horsepower.
Anyone have experience with this? Any thoughts on using the Shankle conversion vs. euro intake?
I would like to know the diffrences of using the GTA style curvedf trumpets vs. a TWM style intake horns http://www.twminduction.com/AirHorn/...williams_1.jpg
It would seem to me that the trumpets may offer more low end torque and better low end throttle response then the open trumpets, but I am not sure. Would be interesting to see on a dyno as well.
I had plan on using a GTA style box over the curved trumpets.
I look forward to hearing your thoughts?
Originally Posted by snj5
Beautiful airboxes and engine bays.
Although not on an Alfa, I've found that height above the stacks is pretty important. There's a guy ( www.durable1.com) who makes a simialar rounded low profile intake for DCNFs that he could make for Alfas. Here's a comparison between the stock DCNF air horn and the 'short stack'. The difference on the dyno was about 8-9 hp in the top end. This gives a lot more effective room over the inlet for better flow.
I've often heard that about .75 inch is needed at a minimum - any one have experience with this?
thanks
-65" Sprint GT (GTA Replica Race Car Project)
-66" Sprint GT Veloce (Project)
-69" GTAm (Project)
-73" 2000 GTV (Orig. Owner)
-75" Alfetta GT (Rally/Street)
-75" Alfetta Berlina (Rally/Race/Street)
-94" 164 Quadrifoglio (1/35 94" Q's imported to US) (Entertaining Offers) http://www.alfabb.com/bb/forums/164-...t-factory.html
02-19-2008, 11:13 PM
When I was buying the air horns for the engine shown above, I found the people at TWM to be very helpful. It's worth a call to ask them for their advice.
Gary Williams
Washington State
'67 GTV
02-19-2008, 11:49 PM
Thanks Gary,
Appreciate your insight. Do you still have the setup shown above? Are you running a airbox with it? Curious how you like it?
-69" GTAm (Project)
02-20-2008, 12:21 AM
wow - it is amazing to see this thread revived; If not mentioned before I'll add some more experiences.
In filtered applications, air filters of the same size become MORE efficient (less resistant to flow with the same filtration size) as the vacuum signal is more steady, or another way to look at it is summated. In combination with the large effect (I have found) of cooler outside air over ambient under-hood air, it seems that there is more to be gained from ducting the intakes as a group to a large single filter away from the under-hood air.
I am still expeimenting a bit, but also management of air velocity PRIOR to the intake air horn also would seen to play a part. I.e., consideration to the character of the flow path with respect to smoothness, length, bends and progressive cross-sectional area to deliver max air at max speed to the plenum containing the air horn bellmouth. We're not talking but maybe 5 - 10 hp here, but it is 5-10 hp and probably affects engine response (which may feel like more).
While I do not know as much about DCOEs past just the 40s, there is an interesting characteristic to the Weber down draft DCNF series I did not expect --- I do not know if applies to the DCOE: for all DCNFs, the entry bell mouth IS THE SAME; both the 40 and 44 DCNF carb have the same inlet bell bouth and carb body casting. The difference is in butterfly size. Where am I going with this? I believe for our cars normally using 40mm carbs, the length of runner (velocity) becomes more important to maintain low rpm velocity if we go to larger (44 or 45) Webers. To turn it around, while the flow at high rpm will definitely be improved, the loss of streetable low rpm response will be exagerrated in larger carbs with shorter air horns. So if you are planning on going to 44 or 45mm carbs, I would not look as much at a short intake stack (unless a full up racer), but would go for a longer one as shown above (but vented to cool air).
02-20-2008, 01:56 AM
Originally Posted by RossoGTV4Me
Thanks Gary,
Yep, it's still pulling like a train. I use an ITG filter that covers all the intakes, as shown here: New Page 1 .
I love the sound of the carbs and enjoy a very strong engine. Still, I would rather have cold air through an airbox. At the time, there weren't as many options as now, or so I thought.
An ITG Tech Support manager in the UK actually went into his back room and found a rolled air horn setup like mine so he could measure it with his air cleaners. He wanted to make sure the air filter he recommended to me would be the best for my use. A critical need is to have adequate air space between the air horn and the air filter. I thought that was service above and beyond the call of duty, so am now a loyal ITG user.
snj5 writes: "...it seems that there is more to be gained from ducting the intakes as a group to a large single filter away from the under-hood air. "
Several friends who are long-time Alfa racer-engine builders agree. They advised me to use a single airbox or air filter, rather than the individual units some people like, because the Webers work better drawing from a single air source.
TWM also let me know that the shorter air horns are best for high rpm power, which is what I wanted. With my engine and a 4:56 rear end, I wasn't worried about low end power. First gear isn't much use anyway, being way too low for anything but climbing trees and starting up on steep hills. Okay, I exaggerate, but not by much.
Gary Williams
Washington State
'67 GTV
03-23-2008, 04:37 AM
Okay, I have a very basic question that I think I know the answer to, but I cant find anything via the search function;
Does the later 105 canister air cleaner offer more breathing and filtration than the early 105 cross-over style? Using my massive powers of deduction I cant imagine that the good people at Alfa Romeo made the change for nothing, but given the option - what would I use?
Like many people, I run a very original series 1 1750 GTV and I'm not interested in wringing every last inch of performance out of it, but seeing I have a later canister here I thought I might give it a try. If its worth my while that is...
