I had to read your question a couple of times to understand it. You're saying that you are already running Webers, but using a Spica manifold + adapto plates. And, you're wondering if replacing that with a factory manifold would bring any advantages. Right? You are not trying to start another "holy war", asking whether you should replace your Spica with Webers?
My guess would be "no", there wouldn't be any significant performance improvement (or degradation). Others may chime in and suggest that it would result in something like shifting the hp peak up/down, based on lengthening/shortening the distance between the butterflies and intake valves. If such a shift were to occur, I would bet the effect would be minimal.
I would suggest that the factory setup brings some benefits in the areas of aesthetics and reliability. Certainly the factory set-up involves less "junk" than a modified Spica - the linkage is definitely simpler. I also like the rubber vibration isolators used by factory a lot better than those double O rings + nylon groove plate things used on the Spica kits. I have found the O rings to swell with exposure to modern fuels, and not seal all that well.
'63 Guilia spider
