Old 07-21-2008, 03:50 PM
Germanyjon Germanyjon is offline
Unhappy Dies on Acceleration..SPICA. intermittent PSI
Got the SPICA on but the PSI is intermittent. Max is 12psi. Engine dies on acceleration! HELP!
Old 07-21-2008, 07:32 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
What is the fuel system pressure with the engine off and the engine running? Is the low pressure warning light coming on? If you squeeze the outlet hose from the injection pump, does the pressure go up to 17 psi?
John Stewart
74 Spider
Old 07-22-2008, 08:46 AM
John, haven't pinched it off yet when there was pressure. Yesterday, there was no pressure until the pump was hit slightly. I'll ask the mechanic to pinch it off if the pump comes on again. Have any idea as to why the engine dies on acceleration?
Old 07-22-2008, 08:48 AM
I forgot. The pressure warning sensor has been removed to hook up the T for the external pressure instrument.
Old 07-22-2008, 03:52 PM
Roadtrip's Avatar
74 Alfa Spider
Ok. Having to tap the pump to "wake it up" is a common sign of impending failure.
John Stewart
74 Spider
