Old 07-20-2008, 10:48 AM
Germanyjon Germanyjon is offline
Fuel Additive for SPICA
I've heard that the SPICA used lead to lubricrate the SPICA. Someone recommends to add Marvel Mystery oil to the fuel. Is the MMO good enough or should I add a lead additive?
Old 07-20-2008, 11:10 AM
Nicola's Avatar
Nicola Nicola is offline
(Un)protected species
Jon -
Wes Ingram recommends MMO on SPICA systems - That's good enough for me!!!
I'd rather be in an Alfa praying to God that we'll make it home, than sitting in a church thinking about my Alfa.
Gordy Hyde
1974 Spider 2000 ~ "Mia" (Carb-free)
1971 Junior Zagato 1750 (1800605) ~ "Zach"
Old 07-20-2008, 11:16 AM
rcess's Avatar
rcess rcess is offline
Same here.
Bob Cess
'59 Giulietta Sprint
'60 Giulietta Berlina
'62 Giulietta Spider
'69 Spider Veloce
Old 07-20-2008, 12:01 PM
Zunige's Avatar
Zunige Zunige is offline
In the Spiders' nest...
The Spica pump needs a lubricant just like an engine needs oil. In this case, the lubricant is gasoline, not lead. This is also why you should never run a Spica pump if the car doesn't have any gas. It's the same as running an engine without any oil. It should also be noted that the Spica pump was originally designed as pump for diesel engines, and diesel is a better lubricant than gasoline. Marvel Mystery Oil improves the lubricity of gasoline. The Spica gurus recommend it as an additive that will extend the life of your pump, since better lubrication means less wear and tear. How much more will it extend the life of the pump? I really don't know. I must also confess that my '74 Spider has its original pump, and I had never used MMO until rather recently. I figured if several gurus who take these pumps apart and rebuild them say that it is a good idea to add the MMO, then it must be a good idea to do so.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
Old 07-20-2008, 01:04 PM
Roadtrip's Avatar
Roadtrip Roadtrip is offline
74 Alfa Spider
4 oz MMO per 10 gallons of fuel. Cheap insurance.
John Stewart
74 Spider
Old 07-20-2008, 02:35 PM
Zunige's Avatar
OK, this post is much too modest! One couldn't ask for a better source for an opinion/recommendation... John is one of the Spica gurus. His great guides and write-ups are a must read for any owner of a Spica injected car.
Best regards,
Enrique
Spider 74, 84 & 87
164 93L & 95Q
Milano 88 Verde
