Mechanical Fuel Pump Rod - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 03-11-2017, 02:27 PM Thread Starter
Would anyone know what the dimensions are (OD x L) of the actuator rod in the mechanical fuel pump. I couldn't figure out why it wasn't pumping until I took it off the block. This is on a 1600 536 block if it matters.
Thanks in advance.
gprocket is offline
post #2 of 6 (permalink) Old 03-11-2017, 02:46 PM
There are 3 different sizes of rods - if it has a spin-on oil filter attached to the front timing cover, it is the long fat one, if it has the element filter in the can attached to the block, it has 2 rods, the first is the thin medium length one that's being driven by the cam on the dizzy, then a short fatter one drives off that, through the triangular casting attached to the timing cover, and actuates the pump plunger. Sorry, I don't have the dimensions to hand at present!
Ian
ianellisalfa is offline
post #3 of 6 (permalink) Old 03-11-2017, 07:57 PM Thread Starter
It is the cartridge style that comes off the block. But I've only notice one rod, about 2" long from what I recall.
gprocket is offline
post #4 of 6 (permalink) Old 03-12-2017, 08:58 AM
Trained (ex)Professional
papajam's Avatar
The other push rod, the one actuated by the oil pump, is under the fuelpump adapter.
Check out this thread for the rod dimensions.
papajam is offline
post #5 of 6 (permalink) Old 03-12-2017, 09:34 AM
Originally Posted by papajam View Post
The other push rod, the one actuated by the oil pump,.
That's what I meant
Ian
post #6 of 6 (permalink) Old 03-16-2017, 12:34 PM Thread Starter
Ok, just to close the loop on this thread and after making up a new rod (the smaller diameter one) of course I found the original. So here is the skinny:
The rod that goes into the block is 6.5Dia x 50mm.
The rod that goes thru the adapter plate and actuates the pump is 5.97Dia x 51.77mm.
Name:  fuel pump pushrod.jpg
This is for this type of pump:
Name:  fuel pump assy.jpg
Thanks for everyone's input.
gprocket is offline
