How to adjust a Fispa Fuel Regulator - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 02-22-2017, 07:14 PM Thread Starter
As best I understand the Fispa FRB 11 fuel filter/regulator should provide 3 psi. I measured mine at 5 psi. Is there a way to adjust it?
- Rich D.
I like Alfas
gprocket is offline
post #2 of 7 (permalink) Old 02-22-2017, 08:38 PM
rafael's Avatar
Yes, with the screen on the top
Spider 2.0i 1992 | GTV 2000 1971 | Giulia Spider 1963
rafael is offline
post #3 of 7 (permalink) Old 02-23-2017, 02:36 AM
kengta's Avatar
I think you meant "with the screw on the top". I agree. With the screw I believe you change the spring pressure on the diaphragm.
ciao
ken
Ken Geiger, Toronto
1965 GTA, RHD, Stradale
ex- 1965 GTA, RHD, Corsa, Trans/Am 66-72
1970 Giulia Super (CDN Spec)
1976 1600 GTj (Italian Spec)
2000 Catalina 320, Hull #765 Northern Dream
2001 BMW Z3 3.0i
kengta is offline
post #4 of 7 (permalink) Old 02-23-2017, 05:00 AM Thread Starter
Thanks guys. I assumed that was the case but didn't want to mess with it in case it was like the SPICA screw that is a no-no to touch.
gprocket is offline
post #5 of 7 (permalink) Old 02-23-2017, 08:54 AM
Gordon Raymond's Avatar
There IS a catch. The latest Viton fuel proof diaphragm is a bit stiffer than the original. If you have an original diaphragm in there and have run with todays "fuel" it will harden, stiffen and eventually crack and leak. If it's original, and pressure is high, you need a new diaphragm.
The new Viton version being stiffer than the original, may also be a bit high. Unfortunately, the adjustment screw will only give about 1# pressure adjustment, + or - on a FISPA FRB 11. Get as close to 3# at idle as you can, and call it good. I recently restored one on a Ferrari, and ended up adjusting it just to maintain extended periods at idle, using the Ferrari FISPA mechanical pump only (no electric pump) for fill pressure / volume. Fuel level in the bowls would drop, mixture lean and then rough or no idle. My suspicion here is the fuel pump may be tired.
Too much pressure will overwhelm DCOE 26gram floats with big needles and seats causing flooding. Too little and you will have low float bowl fuel levels and issues like the Ferrari.
Alfa's Webers like 3# at idle, maybe 3.5#. Not more. If you are running 2.0 needles and seats with Webers with brass floats, 3# is better. Plastic float Spanish Webers will handle more with 2.0 N & S. Most Alfa applications under 2L or non racing use 1.75 N & S with brass floats. Plastic float Webers have different float axle position, and heavier floats and you can use larger N&S's. STILL, all Webers are LOW-Pressure, 3 to 3.5#.
The "Filter King" filter / regulator offers MORE adjustment than the FRB 11, and is a good choice for race applications.
All this from my experience. I hope it's helpful.
Gordon Raymond
Now:
Gordon Raymond is online now
post #6 of 7 (permalink) Old 02-23-2017, 10:12 AM
I installed a new filter king on my Spider last year and I was impressed with how well it adjusts and how stable it is.
85 GTV6 3L
alfaparticle is online now
post #7 of 7 (permalink) Old 02-23-2017, 07:13 PM Thread Starter
Thanks guys. This is a bone stock 1600 with original DCOE 27s (brass floats). The diaphragm is probably the original and replacing it would be wise.
- Rich D.
I like Alfas
gprocket is offline
