Weber 45 upgrade Alfa spider 78 US - Alfa Romeo Bulletin Board & Forums
post #1 of 17 (permalink) Old 12-25-2016, 11:22 AM Thread Starter
alfagk's Avatar
Thumbs down Weber 45 upgrade Alfa spider 78 US
Hi
I restored an Alfa Spider 2L US version and replace the injection by weber carb 45.
i'm struggling with missing cylinder above 3000 rpm
FYI ignition is brand new electronic , new fuel pump ....
It seems coming from the carbs (that they are also brand new)
the setting of the carbs is
Main jet 160
Air corrector 210
It is like i 'm losing one or 2 cylinders when i'm pushing the gaz pedal ...
if i'm accelerating gently on the 2 first stage of the carb it 's ok but when i'm trying to pass to the thrid one (the main) it does not provide power and lose cylinders
any advises ??
thanks
Gerard
alfagk is offline
post #2 of 17 (permalink) Old 12-25-2016, 12:32 PM
Richard Jemison
Alfar7's Avatar
Carbs
Manifold is no issue.
However if you are using the stock cams the jetting is likely to be the problem.
However there are many versions of Weber 45 carbs.
You need to post the exact series which is on the top and the following info:
Idle jets
Main Jets Emulsion tube,
air corrector jets and the choke tube (venturi) size.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #3 of 17 (permalink) Old 12-25-2016, 02:46 PM
hunttheshunt's Avatar
RJ's guess is most likely to be correct; it seems you're flooding the engine with fuel and I wouldn't continue without having an AFR measuring device installed. No detailed advice possible without the requested carb internals info.
hunttheshunt is offline
post #4 of 17 (permalink) Old 12-25-2016, 04:10 PM Thread Starter
alfagk's Avatar
Arrow
Thanks for your quick responses
carb info : 45DCE 152 199 15
Main jet emulsion tube F16
Main jet 160
Air corrector 210
I don't have an AFR controller ... and never used it .
Thanks again
alfagk is offline
post #5 of 17 (permalink) Old 12-25-2016, 09:54 PM
Idle jet and venturi size figures still missing.
post #6 of 17 (permalink) Old 12-26-2016, 06:47 AM
FWIW, here is my 45DCOE152 setup
progression holes - 4
Venturi - 36
main jet - 140
Air corrector - 170
Emulsion tube - F16
Idle jet - 55F9
pump jet - 40
bleed back - 40
My motor has race cams. I would expect the fuel jets to be smaller with stock cams and/or smaller venturis.
85 GTV6 3L
alfaparticle is offline
post #7 of 17 (permalink) Old 12-26-2016, 07:33 AM Thread Starter
alfagk's Avatar
idle jet 70 F 8
venturi is 36
i found also 2 accellery venturi loose moving inside the carburator ... I may explain part of the issue
however do you think the setting is right for an 1978 2 Liters USA version ?
Thanks for you help
Gerard
alfagk is offline
post #8 of 17 (permalink) Old 12-26-2016, 08:02 AM
VabeneGTV's Avatar
Just wondering why this thread is in the Picture thread, should be in Technical under carbs, etc. also judging from alfaparticle's response that he is using race cams and his jetting is much more conservative then yours, you are most likely way to rich! Just my 2 pennies.
VabeneGTV is offline
post #9 of 17 (permalink) Old 12-26-2016, 02:14 PM Thread Starter
alfagk's Avatar
Good catch !! first time i'm using this Forum and I made a mistake
Gerard
alfagk is offline
post #10 of 17 (permalink) Old 12-27-2016, 06:01 AM
70F8 is enormous.
85 GTV6 3L
post #11 of 17 (permalink) Old 12-27-2016, 08:11 AM
Richard Jemison
Alfar7's Avatar
Carbs
If you are running stock (USA cam) then you are not close to correct jetting. Ed is running a pair of cams that in race engines are making over 215 HP. Yet with correct cam timing and his efforts at Carb tuning it is a totally streetable driver. Listen to his advice.
First be sure your Aux Venturies are positioned correctly.(The fuel inlet goes to the upper inside position)
The correct jetting will be "about" this:
F-16 E tube
125 main jet
180 air corrector
idle jet 50 F8
accelerator jet 30
pump bleed back 50
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #12 of 17 (permalink) Old 12-27-2016, 09:14 AM
GTA R's Avatar
The other item which is key to the results are the chokes. What size are they ?
For a standard engine, you should not be running any bigger than 32mm.
The 45's are really too big for your application, you should be running 40DCOE's on a standard engine. You will find it almost impossible to find 32mm chokes for 45's, I've only ever seen one set in 10 years, whereas 32mm are standard on 1750 & 2000 euro engines.
The 40 DCOE's are good for up to 165 / 170 bhp, and can be choked up to 36mm.
To give you an idea, my last GTA Rep ran 40 DCOE's on 34mm chokes on a two litre with extensive cylinder head mods, and much better camshafts, and gave 165 bhp.
I ran it on 45 Dellorto's to start with on 36mm chokes, but it was far more drivable on 40's and smaller chokes.
As others have said above, the jetting is way out too.
If I were you, I'd sell the 45 DCOE 152's and buy a pair of 40 DCOE 151's, much more suitable for your car, unless you're imminently considering modifying the engine radically, with extensive porting, higher compression, maybe bigger inlet valves, performance cams etc.
You could offer to swap with cash your way for a pair of 151's, as 45's are more valuable than 40's, provided they are in a similar condition.
GTA R
Giulia Ti Super Rep yet to finish. BMW 2000 NK to Ti spec
GTA R is offline
post #13 of 17 (permalink) Old 12-27-2016, 12:13 PM
I agree. My motor made 169 HP with 40DCOE116/117 "emission" Webers with 34 mm venturis and stock mufflers.
I now have 45DCOE152's, 36 mm venturis and a less restrictive exhaust and the motor makes more top end power but the fuel consumption has gone up from about 23 mpg to about 18 mpg and the response below 3000 rpm is not as good.
85 GTV6 3L
post #14 of 17 (permalink) Old 12-27-2016, 12:24 PM
Post #7 says: 36mm.
May be you watched over 10 years the wrong websites; 1600 GTA Stradale even had 30mm chokes as standard in 45's. No problem to buy them in any Weber specialized shop; starting from 30mm:
45DCOE - Webcon UK Ltd
post #15 of 17 (permalink) Old 12-27-2016, 07:54 PM
Richard Jemison
Alfar7's Avatar
Venturies
If I wanted smaller choke tubes I would call Pierce manifolds and order them as they are available from 28mm to 40mm.
No reason to go to smaller carbs, It`s all in the tuning. The std carb on the GTA was 45 DCOE 14 with 30mm chokes.
As to cams, widen the LSA. If you are at 104 on the intake move the exh to 108..
Some old threads on the same subject:
Weber 40s or 45s?
http://www.alfabb.com/bb/forums/carburetors-fuel-injection-air-intake/59786-venturi-size-post503983.html.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
Replace with
