There were four main critera associated with me choosing paint for my Duetto Restoration.
Cost of the Paint
Single Stage or Multi Stage
Availability of Paint forumulas
Capability of your body shop
Cost of Paint
Each paint manufacturer has multiple paint lines. An expensive, medium, cheap, etc.
The top end of each paint line will always look better, but they can get expensive. I chose to use Glasurit 22, which was hundreds of dollars per gallon. Get into the low end paints and it looks like someone poured plastic over your car.
Single vs Multi Stage
Each has their own pros and cons. No opinions given, you need to research the differences for your self.
Availability of Paint formulas
Each paint line has a different formula for each color. Sometimes they don't have a formula for a particular color in a particular paint. I had to get my paint custom made because Glasurit did not have a formula for the color. Most reds are pretty common and available.
Capability of Your Body Shop
Do not assume that a body shop knows how to shoot any kind of automotive paint. They all have their small tweaks that need to be considered. For example, shooting Glasurit 22 Single stage requires a gun slightly different from a gun designed for Dupont stuff. If you first find a body shop you like before you choose your paint, this might lead you to your answer.
