Old 09-13-2004, 09:34 PM
roller roller is offline
insulation in '69 gtv
i'm really tearing into the cabin of my '69 gtv.
i've taken out seats & center console & carpet.
i'm also taking out the thick insulation. there's a lot of dust...is the insulation a health hazard in any way? is it fiberglass or asbestos?
thanks,
john
Old 09-16-2004, 06:53 PM
guessing...
i'm guessing that my concern over the insulation of firewall/floor in my gtv is misgiven or is too ridiculous to respond to.
i looked more closely at the firewall insulation, and even tho it's the same color as fiberglass, it looks more like shredded cotton.
john
Old 09-17-2004, 07:30 AM
jimcheney jimcheney is offline
I tore all mine out without lung protection and I havent died yet. I was careful...
I dont know its composition though, I just knew i didnt like how it retained water. Mine had been seriously soaked from a leaking heater core.
Old 09-17-2004, 08:47 AM
ossodiseppia's Avatar
pffffffffffffffffffffff!!
I tore mine out ten years ago, well what little was left got torn out. I'm still alive and kicking to some degree. It wouldn't surprise me if that stuff has natural fibers in it. If you are planning on replacing the insulation, I'm very happy with the stuff I used on my car. It's easy to cut and install. If your interested in what I used, please feel free to check out my website. All of the info is there.
Old 09-17-2004, 02:29 PM
great...
great, thanks ossi.
good to know there's at least no short-term effect.
i'll check out your site; i'm going to have to replace it
with something.
john
Old 09-17-2004, 04:17 PM
Keven's Avatar
Keven Keven is offline
John,
I tore all my insulation out,(what a mess!!) I wore rubber gloves, and a Home Depot cheapy mask. Better safe than sorry.
One note, is that under the carpet insulation, Alfa added more soundproofing
in the form of tar(bitmus sp?) mixed with asbestos. Be really carefull if you are
planning on removing this. I plan on getting it good and wet, wear a better
mask, and bagging the stuff as a scape it off. BTW they paint right over this
stuff. Good luck.
1978 Spider sold in 1996
Old 09-17-2004, 05:55 PM
ouch
yep, the stuff under the carpet is what i'm talking about. that's unfortunate if it's asbestos. i tore most of it out to clear the floor pans for replacing.
well, i hope i didn't inhale too much of it. thanks for the update.
what with the exhaust fumes and the asbestos, my health seems to be in jeopardy w/ this car.
i'm going to check the site to see if there are warnings about the asbestos.
john
Old 09-17-2004, 11:20 PM
116_Veloce's Avatar
116_Veloce 116_Veloce is offline
Send a message via ICQ to 116_Veloce
The original stuff is made of shredded fabrics and cardboard
Azzurro, e troppo lungo il giorno per me...
Old 09-18-2004, 09:30 PM
i'll go...
i'll go with that (the optimistic version).
the floor did look like shredded sweat shirts.
the firewall was the same color as fiberglass, but
looks more like a kind of cloth.
in any case, i'm going to be using the mask next time i tear into it.
john
Old 09-20-2004, 06:55 AM
Ok then, what is all that silver-backed stuff you see people put under their carpets as a modern replacement? Either that or does someone have a recommendation for a insulation replacement?
Old 09-20-2004, 09:06 AM
Keven's Avatar
I hate to be the bearer of bad news, but the stuff does have asbestos.
Its printed in my factory Alfa workbook. I think it helps soundproof as
well as insulate the cabin from exhaust heat.
You will probably be just fine, since most of it is incased in the tar.
I have noticed that removing it was not that dusty so far.
Also do take care of the exhaust smell, the likely culprits are the trunk seal.
Search the BB for this topic, because some have not had luck with certain
seals from Centerline and International. People do say the Re-Originals
does work. Also check that your tranny shift lever boot is not ripped.
There are two boots an inner and outer, inspect both.
Good luck, and start wearing a mask
Old 09-20-2004, 02:03 PM
Jr. Z Jr. Z is offline
Insulation Composition Questions: I took some of these products to someone who knows about asbestos abatement & removal when I was taking the car apart & he gave me a quick analysis, no testing, just his best educated guesses on the composition of the different materials:
1) Black tar/bitumen based material right next to the floorboards, stuck down & painted over in primer or body color: He thought it DID have asbestos in it as the fabric reinforcement, but pointed out that is encapsulated & the fibers can't fly around easily. Take it out in chunks, dispose of correctly, don't cut/grind/shred the stuff, you should be OK. Wear particulate masks.
2) Cotton/chopped fabric material: He thought it looked like chopped scrap fibers, cotton & other, didn't see any sign of asbestos.
3) Pink Fiberglas material: Looked like pure fiberglas to him, just keep it off your skin if you don't like to itch. Wash in cold H2O & soap afterward to keep it from getting into the pores of your skin. The tar hard stuff on top of some of this looked the same as #1 above, same precautions about breaking it up.
4) Now the Baddie: The exhaust heat shields have a layer of PURE ASBESTOS on top of them, between the sheetmetal shield & the body. This is not encapsulated, needs to have every precaution against breathing the fibers taken. If you are going to remove or mess with it, do it inside a large closed plastic garbage bag & dispose of it properly, take it to the proper disposal facilities & tell 'em what it is.
Bruce
Old 09-21-2004, 05:23 PM
Touringspider Touringspider is offline
An Alfa restoration buddy of mine works in the environmental sciences and waste remediation field. His opinion on all these types of materials is that if you take sensible precautions your risk of injury is low if you are doing a single restoration. The key is not to make the material friable (that is, don't remove it from its encapsulated state and get it airborne). Thus, don't cut it, grind it, or blow it with compressed air (which is how all those old time brake techs got sick from the old asbestos brake pads). Also, your risk depends on your level of exposure. Occupational exposure is obviously more dangerous than a single occurrance.
My advice is to invest in a good face mask instead of those all purpose paper things with the two rubber bands. It may cost you more in the short term, but it is worth it. I wear mine religiously when doing any grinding, sanding, or just tearing out old carpets etc. If nothing else, it keeps your allergies from acting up. Oh yeah, read the label to make sure the cannisters are appropriate for your application, and replace them regularly.
Those exhaust heat shields do look scary, don't they...
Arno Leskinen
AROC National Concours Chair
102
115
116
  #14 (permalink)
Old 09-21-2004, 08:43 PM
SeekGTV's Avatar
SeekGTV SeekGTV is offline
Bruce
I work in a very large and very old manufacturing plant. We have had to deal with a considerable amount of asbestos removal. The team that came in made a couple of recommendations that I think are appropriate here.
In a situation like Bruce mentions under #1. If at all possible leave it alone. It's already encapsulated & the fibers can't fly around easily, 'leave it be and it won't bother you'. If it must be removed follows Bruces instructions as they are very good. Wear a mask and don't grind/saw/shred the material.
In a situation like Bruce mentions under #4, Bruces friend is again correct, this is the nasty stuff and it 'must' be removed. The trick is to encapsulate it so those dangerous fibers can't fly around easily. The abatement team suggested spraying it with a clear polyurethane paint in heavy amounts. As it drys; but, while still a bit tacky enclose the area with plastic and seal it all but enough room for one hand. While wearing gloves and an mask remove it in as large of chunks as you can and let it fall to the bottom of your containment area. When all has been removed, allow it to settle for a minute or two and then undo the plastic while resealing it gently around the asbestos. Dump into a plastic bag and seal. Now just dispose of it properly.
The spray paint will encapsulate the fibers and reduce the risk.
Oh and Arno is also correct short term exposure is not the end of the world.
[B][I]George[/I][/B]
[U]Current Stable[/U]: 65 Giulia spider/03 Audi A6 2.7t BiTurbo 6spd.
  #15 (permalink)
Old 09-23-2004, 05:31 PM
where...
wow, thanks. i had no idea about any of this stuff before. if the asbestos in the driver's compartment insulation is in the layer of tar on top of the fiberglass and shredded cotton, then maybe i didn't suffer too much.
i'll be using a mask next time regardless.
thanks for telling me about the exhaust system! i didn't have a clue.
i'm assuming you're saying that the asbestos is sitting on the topside of the
exhaust system before it meets the chassis floor. i'm also assuming that it's just over the mufflers -- i don't see anything on top of the exhaust pipe.
what should i look for? is it a gray sheet? how is it fastened to the exhaust
(or the chassis)?
is there *anywhere* else on the car that has hazardous components?
thanks again, please forward relevant wisdom.
john
