Old 04-28-2004, 12:21 PM
tgal60a tgal60a is offline
69 GTV restoration
Hi All, new to the board, I am restoring a 69 USA model GTV and need some info on restoring the center console and possibly some pictures in order to keep original. I need to re-surface the center console with new vinyl but, would like to know if there are any places that sell these consoles as mine seems to be in need of repair.
Old 04-28-2004, 08:04 PM
116_Veloce's Avatar
116_Veloce 116_Veloce is offline
Send a message via ICQ to 116_Veloce
Greetings!
First, if you think you can do the console yourself, I'd suggest you do.
Finding a good used one is very hard (especially for the old GTVs) and they cost alot.
My suggestions to you are:
CLEAN the console very very thoroughly before you begin. Strip all the old vinyl,
then use paint thinner to clean the residues of glue etc.
Then you should give the console a good once over with fine sanding paper, so that
the new vinyl will stick. Ofcourse if you need to make any repairs do it now,
any good 2-part epoxy will do.
If I am not mistaken the original vinyl is still available but it is not cheap (I don't
know if you want to go concours but if you do just know that it is possible).
Cut the vinyl much bigger than the console (better that then to make a mistake and
then start all over again).
The best glue to use is spray-on glue. Work slowly while sort of "caressing" the vinyl
onto the plastic.
After it's stuck on there, leave about 1" material so you could wrap it around
the edge later.
If all this seems too hard, take the console to an upsholstery shop, but DO clean
it up yourself, I doubt they will do it as well as you do.
The older GTV consoles are quite straight-forward and much easier to do than
the newer consoles who have bumps, corners and curves which are harder to trace.
As for the veneer, I think you can buy ready-made stuff and just cut it using the old
one as template.
Any other questions I will gladly answer.
Azzurro, e troppo lungo il giorno per me...
Old 04-28-2004, 09:28 PM
Thanks for the replay 116_veloce. I have been doing what I can myself for the reasons you mention, no one will take the time to restore properly except yourself.
