06-24-2006, 05:22 AM
Originally Posted by Stathy
Since we're on the topic of rust/pin holes, what are your opinions on areas of metal that have been stripped to bare metal but look like Swiss cheeze?
Does braze welding (bronze) work well in this situation or is the cut and replace method the only way to go?
Holes can easily be welded up. Hold a piece of copper on the back side of the hole and weld from the front. The weld will no stick to the copper.
09-29-2006, 08:45 PM
Thank you Mike! You've given me a new direction on my current resto.
Elcid
12-11-2006, 08:50 AM
Great info on body filler here. I'm sure you cleared us some confusion and issues for many people. Great job!
01-30-2007, 05:38 PM
Originally Posted by GoldCloverLeaf
Ok last post i swear :P
Taken from another one of Mikes informative posts:
"As people have mentioned elsewhere, many will prime the entire car with epoxy and do the bodywork on top of the epoxy. The advantage to this is the epoxy protects the metal while the bodywork is being completed. The disadvantage is the body filler creates a stronger bond to bare metal than to epoxy. The manufacturers officially do not recommend this, but will admit that it has its advantages. I do not do this."
Epoxy primers such as PPG DPLF work as adhesion promoters for the fillers applied over them. I'm surprised to read that any professional would still be applying filler over bare metal. I've used DP & DPLF primers as a base on all my restoration work since it was first introduced. That includes 17 years doing show quality restoration of vintage/antique motorcycles for customers all over the U.S. & have never had a failure.
05-22-2007, 05:28 PM
As well we should not forget that heat causes condensation when applied over bare metal will cause rust which we see a lot in old lead jobs  , but this is (according to I CAR) the reason for the epoxy primers under modern fillers, not so much for adhesion but for controlling rust. Modern fillers while under going their chemical change heat up and yes can form condensation on bare metal. I also was uneasy applying filler over cured epoxy even though the paint companies tell you it is o.k. I still prep my panel or grind like I normally would, apply epoxy,: once it has cured then hardblock the area with 80 grit before applying the filler
10-08-2007, 10:06 AM
Originally Posted by Timo
Mike,
Thanks for explanation of body fillers and their proper use. A resto shop owner once told me the exact same thing about the mis-use of bondo/body fillers and how these products are getting a bad rap because of it.
I'm currently doing a brand X rolling resto job on an old BMW. I was wondering what you thought about using the aformentioned body fillers(any and all the ones you mentioned)and if they were suitable for filling up small holes in the panels where some "aftermarket crazed idiot" (pardon my judemental expression) mis-drilled holes for mounting non OEM badges and name plates ect...in places where they were not meant to be. These holes for mounting the badges seem to be farily standard in size for most cars and in this case they are about 1/8 in diameter maximum.
Most, if not all, of these holes will be covered by the badges when they are remounted in thier correct location. Do you think it better to just weld them up as opposed to using body filler? Thanks in advance.
I had a similar situation and found that weldong comes in real handy. I welded in the holes that happened to me. Came out real nice and still holding after 9 years. . .
[B]1969 Alfa Romeo Spider Round tail
SPICA fi[/B]
[B]1967 Austin Healey 3000 MK III[/B]
All original. Still going strong!
[B]1963 Triumph TR-4[/B]
My first ever project car. Daughter using as a daily driver.
[B]1959 Austin A-40 Farina[/B] (as in Pininfarina) RHD
Twin S/U Carbs, 1950's race header & exhaust.
[B]1958 Austin A-40 Farina[/B] (as in Pininfarina) LHD
Currently using Davis Vizard's book "Tuning the A series engine" for reference & a great build on both A-40's.
11-20-2007, 02:46 PM
I just joined this forum, but I thought I'd chime in. I too hold to prepping the bare metal before ANY filler. This being both an etchant wipe, followed by etch primer. I know, a little redundant, but once a body is media blasted or sanded bare, rust can start forming microscopically in seconds under the right conditions. Doing the etch first helps insure long time no rusty!!
11-27-2007, 03:44 PM
87 Milano (Silver) Body Restoration/Repair
Evening all,
An excellent "Body Repair 101" post. I would like to get some repair work done here in NY City on my 87 Milano - It has plenty of rust. As I'm a student my resources are extemely limited. Do you know of anyone in New York who has worked on Alfa before and therefore understands all the nuiances associated with repairing these timeless classics? I would appreciate any help on this one.
Thank you.
Jr. Lee
12-08-2007, 09:14 PM
fellow bb members. Please excuse my ignorance but i am half way through the restoration of my car, i have removed the rust in sections and welded new metal on top of my repairs. I will now require a light coat of filler.. Should i apply a special filler over the bear metal to seal the welds? or should i apply a primer of some sort over the metal before the filler is applied if so what type of primer? epoxy? etch? also what type of filler would be best to be used over the primer?
easy sand? etc?
all help is appreciated
12-21-2007, 03:09 PM
can someone please help me??
12-21-2007, 04:30 PM
easy sand? etc?
Generally, the filler goes on first, then the primer. (The earlier parts of this thread have some good information on this.) In between, is a lot of prep work i.e., lots of metal streightening and old fashioned block sanding to get an even paint surface.
I am not a painter so I won't go much farther than this. There are some very good body men/painters on the forum so perhaps one of them can give you more complete recommendations.
I can suggest that you visit your local Borders book store and look in the car section. There are a number of excellent books on car painting. Also, it certainly wouldn't hurt to make friends with your local automotive paint store. The people who work there often know quite a lot about their products. I've usually found their advice to be good.
04-01-2008, 07:32 PM
Better yet, dont pay for those books! Go there, write down the titles/author, then call your local library and request that book through inter library loan. Youll get it maybe within 1-3 weeks. Keep it for the time allotted. Then give it back. Free book use!!
05-18-2008, 09:25 PM
Here's my two cents on the filler issue. I don't believe in putting any filler over the top of a primer, whether epoxy or not. The rule of thumb to always follow is that your final project is only as strong as your weakest bond. Primers adhere excellently to filler and filler to metal, but not so much primer to metal.
Of course, I don't apply the filler directly over the top of the metal either. As EdP touched on, it's generally best to do an "etch" first. This is typically a phosphoric acid based solution and is also called "rust-mort" or "rust converter", but is NOT navel jelly! Once the metal is bare and clean I take a small amount of etch on a rag (wear gloves for pete's sake, this is acid!! ) and wipe down the surface of the metal. Rust is oxidized metal; as such as soon as you expose the metal to oxygen it will start oxidizing. Whether or not you can see it, if the metal has been exposed for ANY amount of time it will have oxidation. The etch stops the oxidation cold and keeps any futher oxidation from happening. The etch will also leave a slight film on the surface which can be removed with a quick wipe down of wax and grease remover. A gallon of good etch is about $30 at your local paint store and I feel it is an essential item for anybody doing body work.
05-19-2008, 07:32 PM
This is not correct, I believe. Metal needs to be sealed first, otherwise it will sweat and rust will start under filler.
Please ask Daron (akitaman) this question.
05-20-2008, 08:34 PM
Pete, I don't paint cars but I can describe the process, having observed an expert at work (what can I say this is what anthropologists do. . . ). Tony, the guy that taught me this stuff was very catholic about prep work. He never put Bondo, lead (which he did not like) or brass filler over primer or sealer. Never. He always made sure that the bare metal surface was absolutely clean and prepared before he applied filler (which he used in very sparing amounts---paper thin more or less). His view was that filler adheres better to a bare metal surface.
I'm describing decidedly "old school" techniques. The technology has obviously advanced since the 80's when Tony was last working. I recently saw an article in Grass Roots Motorsports which described surface prep in which a thick primer/filler was sprayed over the car and then the high and low spots were worked on. Tony would never done it that way. With his cars you'd see lots of smooth, bare metal with small areas of filler. And, if you had enough money, you could see an entire car ready for flawless, concour quality paint with no filler at all. His view was that the less primer/filler on the car the better. He wanted his work to last a decade or more, which it often did.
These are just observations. Daron and others on the bb who actually do the work are, of course, the experts.
