Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Boxer Engined Alfa Romeos
Old 05-18-2008, 07:56 AM
Hilario Hilario is offline
Alfasud distributor rotors
Hi
A time ago I buy 2 alfasud sprint veloce to restore, I can't use any yet, but I noticed that the have the same distributor but different rotor arms, I think the big (1) is a limiting rotor, what is the best to use?
Thanks very much anny help
Old 05-18-2008, 11:03 AM
dave33's Avatar
dave33 dave33 is offline
I have normally run the rotor without the limiter, I found that when the limiter cuts, it is a TOTAL cut, the motor just cuts out completely till the revs decline a bit, its not the "soft" cut/misfire you get on a more modern rev limiter.
If you might at some stage lend the car to someone without as much respect for it as you, then the limited one might not be a bad idea....!
1989 Alfa 33 1.7 QV (x 2)
1 for the road
1 for the track
ALFA - Always Looking For Another ??
Old 05-18-2008, 04:21 PM
Spooty22 Spooty22 is offline
The rev-limiting rotor cuts in alot harder on your wallet too!
I priced both some time ago at supercheap auto here in Australia.
The rev-limiting type was $140
The normal type was $10
Old 05-19-2008, 04:57 AM
spottie's Avatar
spottie spottie is offline
You're right about the price differential. I found it was cheaper to get one through the local Alfa dealer than Supercheap. The other benefit is that they will get you the right one as well.
I tried the std rotor in my Alfa and it didn't last , so put the rev limiting one in and it's going well. I also changed the coil to a Jacobs which seems to be better than the original Ducellier.
1987 1.7 QV. Everyday driver
1986 1.5 Sprint QV under resto
