Hey Guys.
The popping is normal and can sometimes sound good.
Its caused by a lean micture in the idle circuit.
Sometimes cured by adjusting the idle mixtures correctly,at engine operating temperature.
The right way is to go up 1 size in the idle jets and reset the idle mixture screws.
Car will start easier from cold,the progression from idle mixtures to main jets will be heaps better,and goodbye popping.
Idle mixture jets work from idle to about 2,500 rpm.
I have done many idle rejets for my customers cars,and they love it.
For the cars with points,make sure the point gap is right and the ignition timing is correct before rejetting.Same goes with electronic ignition.
Robert
1972 105 GT Veloce 2000
1976 2L Spider
1984 GTV 6
2L Berlina grey,needs new home
