Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Boxer Engined Alfa Romeos
  #16 (permalink)
Old 04-30-2008, 04:20 AM
33gold's Avatar
33gold 33gold is offline
I don't have the dark grey box on mine, I assume there is a thermostatically controlled by pass in there. I may run ducting from the alloy elbows to down behind the headlamps with foam filters somewhere. Be careful getting two much air as your torque will more than likely go down; I had some Fiat Abarths that had ram pipes etc as standard plus an airbox half the size of the Alfa, when you removed the box you lost about 10% torque. In the old days we used to pipe the inlet to an area of low depression not in direct flow for this very reason. But hey i'm an old fart and things change.
Current: Alfa 33 QV Hillclimb project Previous: Fiat Abarth 130TC (x2), X19, 131 Racing, Lancia Delta, Fiat Coupe 20v Turbo (what a car )
  #17 (permalink)
Old 04-30-2008, 08:41 AM
darkcue33's Avatar
darkcue33 darkcue33 is offline
Yeah, i'll just take off that thermostate thingy as i dont think it works, i will get some flexi tube for cold air straight into the airbox, i will have to find some tube first!!
Current : 1985 Alfa33, 75 Ford LTD, 1990 Lancia Dedra Turbo(stored in Scotland)Previous : 1999 Fiat Seicento Sporting, 2000 Fiat Punto GT, 1990 Alfa 33 1.5ie, 1997 Alfa 146ti.
  #18 (permalink)
Old 05-06-2008, 07:50 AM
darkcue33's Avatar
Thanks to everyone for all the suggestions! Once i source some tubing i will have a play around and let you all know how i get on.
  #19 (permalink)
Old 05-09-2008, 11:39 PM
900 series's Avatar
900 series 900 series is offline
If Cold Air equals more power then less weight must equal faster acceleration and your A/C weighs about 20kg right?
I have fitted a primitive cold air intake to my car, but before this i took my A/C off and put it in a dark corner of our shed...
Driving:
Alfa 33 1.5 4x4 Wagon
  #20 (permalink)
Old 05-13-2008, 06:49 PM
darkcue33's Avatar
I can get some new tubing = 1 metre in length, 60mm diameter.... for $15, would this do, as i dont want to buy it if its the wrong diameter??
  #21 (permalink)
Old 05-13-2008, 10:54 PM
Greek Greek is offline
I think that you should go for 65mm because it has to overlap the of the intake tube on the car next to radiator.I have bought a 65mm on my sprint and was a perfect fit ....
Sprint 1.5 '86
www.alfisti.gr
  #22 (permalink)
Old 05-29-2008, 07:42 AM
darkcue33's Avatar
I got some tubing today, it fits onto the airbox perfectly but i am having trouble getting it to fit beside the radiator to get the cold air............the bloody air con **** is in the way!!! i will post pics tomorrow t c if anyone can suggest anything.
Articles
