Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Boxer Engined Alfa Romeos
  #31 (permalink)
Old 05-09-2008, 05:07 PM
oz3litre's Avatar
oz3litre oz3litre is offline
Originally Posted by m.jansen View Post
@lenus: sorry for my english
No need to apologize for your English. It is better than some native English speakers are capable of writing. My daughter is planning to visit the Netherlands in a couple of months time. She is currently staying with a friend in Italy and is going to visit some friends in Hamburg and backpack to Holland with them.
1988 Alfa 75 3 litre
1988 Alfa 33 1.7 TI
1990 Volvo 480 Turbo
1984 Alfa GTV 2000
1992 Alfa 164
  #32 (permalink)
Old 05-09-2008, 05:33 PM
m.jansen m.jansen is offline
Thank you
great, sounds like a nice trip
if they ever come near a small place called Odiliapeel we can have a chat
  #33 (permalink)
Old 05-22-2008, 02:25 PM
after cleaning a carb the engine runs good again so for who is interested,
here is a video of my 33 in 2nd-3th gear
YouTube - alfa 33 16v carbs 181hp fly by
  #34 (permalink)
Old 05-23-2008, 04:03 AM
33gold's Avatar
33gold 33gold is offline
sounds nice there m.jansen
Current: Alfa 33 QV Hillclimb project Previous: Fiat Abarth 130TC (x2), X19, 131 Racing, Lancia Delta, Fiat Coupe 20v Turbo (what a car )
  #35 (permalink)
Old 05-23-2008, 06:51 AM
lenus's Avatar
lenus lenus is offline
God that sounds hot.
It's like my car on the most expensive steroids money can buy... The pickup in 2nd gear is just incredible!
Does it have the standard 16v ratios?
lenus.
  #36 (permalink)
Old 05-24-2008, 04:10 PM
Thanks guys, if i let engine make 6500+ rpm the pickup is great in all gears
Yes its a standard 16v gearbox, 3000rpm@ +/- 60 mls/h in 5th gear
  #37 (permalink)
Old 06-26-2008, 09:31 AM
had to go to the dyno again, after some problems with ignition timing.
it dropped back to 159 hp... now i got all my horses back
  #38 (permalink)
Old 06-27-2008, 05:29 AM
33gold's Avatar
Sounds gr8, don't get that from jap crap!
how do you find the trumpets, did you ever have the std elbows on?
  #39 (permalink)
Old 06-27-2008, 04:43 PM
had std elbows on for only one day, dont know about diffrence in performance but
it sure had a less cool sound.
we found out while testing my red 33 carbs (on a dyno)that the standard elbows
work a bit the same as trumpets,without the elbows the engine had about 4 hp less.
(so the std elbows improves airflow to)
  #40 (permalink)
Old 06-28-2008, 08:50 AM
baldy baldy is offline
1.7 16v boxer on carbs
I would be interested to know, what size chokes and jets you are using in these carbs, i am assuming these carbs are 40 idf carbs? Also what are you using to control the timing ? The reason i ask is i have done the same on my alfa sprint, see picture below. thanks lee
  #41 (permalink)
Old 06-28-2008, 09:06 AM
hi,
yes i have 40 mm carbs with 32 chokes, dont know the jet size have to look for that.
i,m getting myself some 34 chokes soon.
i recomend strongly to get your car on a dyno for timing of ignition and carbs!
if engine runs lean on feul your engine will die, if timing of ignition is not good
pistons can die to!and it will get max hp out of your engine(see my 147hp 33).
(i had one 1.5 engine that died like that after 5000 miles or so)
  #42 (permalink)
Old 06-28-2008, 09:23 AM
What we found was with the extra valve area of the 16v the engine had a much stronger vacume signal (pulls more fuel through at idel jets) we over came this by putting .45 idel jets in rather than the standard 8v .50 jets.this allowed cleaner burn and better drivability low down the rev range, ie more power. I olso am using 32mm chokes max power@6200 revs, due to the choke restriction(air flow restriction), 34mm chokes will give you more top end power ideal for track use, and if you like full throttle.but you will loose out in driveability and torque. does your car idel well in traffic? I would be really interested to know what jets air bleeds mains and emulsion tubes you arre using. thanks
Articles
