I should explain....I've ditched the airbox in favour of the filters (100mm) and radius pipes because my Sud is a racing car....or at least wants to be !!!
....to accommodate the cold air induction I've removed the inner headlights and replaced them with mesh !! The space for the inner lights sits right in-front of the filters and now creats a forced induction effect.
I'm considering running an internally baffled airbox which incorporates the carbs and filters...by running induction pipes from the inner headlight position and including baffles to negate the turbulence I'm thinking I can get a lot more good air in there !!
My exhaust has also been redesigned...it no longer includes the 45 degree bends and exits between the drivers door and the rear wheel-arch
...sounds a bit wild though !!
...eventually I'm going to hunt down an Iresa crossover manifold, but it could be a while
