#16 (permalink)
Old 03-05-2008, 03:47 AM
ALFA33boxer's Avatar
ALFA33boxer ALFA33boxer is offline
Originally Posted by ZeNiTh-PbArM View Post
Hi,
having installed a fuel flow meter on the dash (electronic device computing the product of injection time and engine rpm)
Hi!
Fuel flow meter, interesting , if I could have one...
Where can I find one???
Cheers,
Alfa33boxer
[B][I][U][SIZE="5"][COLOR="Red"]ALFA 33, serie 3, 1.3 IMOLA[/COLOR][/SIZE][/U][/I][/B]
  #17 (permalink)
Old 03-05-2008, 09:57 AM
ZeNiTh-PbArM's Avatar
ZeNiTh-PbArM ZeNiTh-PbArM is offline
uuuh did not find one so built mine myself! spent some time figurin how to talk to the ECU though...
all the best,
zp
  #18 (permalink)
Old 03-06-2008, 01:28 AM
all the best,
zp
he he he he, this is a good one ha ha....I wish I could talk to my ECU too so we can be very good friends with each other
Can you show me haw???
Best,
Elvis
  #19 (permalink)
Old 03-23-2008, 04:16 AM
keith_h keith_h is offline
I've just filled up my sons 33, a single carb 84 1.5 and put 30 litres for 387 km, makes for about 36mpg around town.
Heres a calculator for those struggling with the math: The Fuel Calculator
[SIZE="2"][COLOR="Blue"]Keith[/COLOR][/SIZE]
[SIZE="2"][COLOR="Silver"]85 Quattro Monte Carlo[/COLOR]
[COLOR="Red"]33 GCL[/COLOR]
[COLOR="DimGray"]Previous cars[/COLOR]
[COLOR="Silver"]Alfetta
Guilia Sprint GTV[/COLOR][/SIZE]
  #20 (permalink)
Old 03-23-2008, 07:56 PM
From the S1 33 owners manual with my conversions to mpg:
1300 1500 TC
90km 5.5/51.36 5.7/49.56 6.2/45.56
120km 7.9/35.76 7.5/37.66 7.9/35.76
mixed 9.6/39.43 9.8/28.82 10.9/25.92
If anyone can tell me how to format this nicely I will.
  #21 (permalink)
Old 03-24-2008, 03:40 AM
77SudTi's Avatar
77SudTi 77SudTi is offline
Not sure if anyone else has noticed this, but I get very different mileages on a tank depending on where I buy fuel. I bought $20 worth from BP the other week and got 200 odd Kms. $20 from caltex gets me 120kms...Fuel quality plays a big part here!
Maybe investing in a 1L can of Xylene to boost octane will be a cheaper option soon anyway...clean your carbies while u drive! (just advance your timing a degree or two)
- '77 Sud Ti - Project car - C pillar "Ti" stickers needed!!
- '88 series II 33 1.7 Weber'd - More mint than yours!
  #22 (permalink)
Old 03-24-2008, 06:50 PM
Erm, why would you advance the timing??
And you might want to check this out as well: Media Watch: Mileage Misinformation (25/02/2008)
Five identical vehicles, each with a different brand of petrol, set off from Sydney for the Hunter Valley.
But the content's another matter. En route, the expert from Wheels magazine tells us that there's no difference between one brand of petrol and another.
Turns out they all buy and supply petrol from each other.
While we are here, this is a good article on some of these topics including Octane and changes with the new fuels: Technical Article #3
Yes it refers to old Holden engines but since we are talking about old boxer engines I though it was appropriate.
As I noted in another post, I am using PULP (95) which stops the pinging but is less than the RON for leaded fuel previously (98).
  #23 (permalink)
Old 03-24-2008, 09:02 PM
77SudTi's Avatar
"The tendency to knock increases as spark advance is increased. For an engine
with recommended 6 degrees BTDC timing and 93
octane fuel, retarding the spark 4 degrees lowers the octane requirement to 91, whereas advancing it 8 degrees requires 96 octane fuel"
7. What parameters determine octane requirement? (more here)
Ever set up your engine to run PULP, and stuck in normal unleaded then driven up a hill? Noticed the pinging? Thats because the octane rating is too low for that ignition timing, retard the timing and it wont knock
  #24 (permalink)
Old 03-24-2008, 10:09 PM
OK, got it now. I was just wondering about what you said earlier in case I missed something. I presume then that your car is configured for running regular unleaded.
I run PULP all the time because as you said the regular makes it ping and generally run poorly. But the timing is not set specifically to favour one fuel or the other. The user manual does not specify a grade of fuel so for these earlier cars I presume RON 98 which was "super" when leaded was available. Hence using PULP now which is the closest thing you can currently buy from a pump.
  #25 (permalink)
Old 03-25-2008, 01:11 PM
kid808's Avatar
kid808 kid808 is offline
i get round 100ks outta 10lts average in my twin carb 85 1.5lt 33 no matter how i drive it doe's seem 2 get better on tha highway though @ higher rev's and doe's any 1 know were i can get a bonet scoop 2 fit ?gets hot here in qld n from experimenting i really think tha car would benifit from it
  #26 (permalink)
Old 03-27-2008, 02:58 AM
Many folks make the mistake of removing the standard airbox because it sounds better or makes the car go better, however that is not the case. The standard TC airbox is engineered to perform and has a cold air inlet that connects around the headlight somewhere which means it takes in air from outside the engine bay if it's all hooked up right. Most of them have had the flexible hose fall off years ago however. I have also removed the thermostat and flap off mine as well.
If you want to go the cold air route, I recommend getting the flexible hose hooked back up but I doubt you'll find it makes any difference. It will save turning your 33 into a Suburu look alike though which can only be a good thing.
Let me know if you want more information.
  #27 (permalink)
Old 03-27-2008, 11:32 AM
Hi,
thermostatic flap removal is likey to cause carburetor misting in cold weather. I remember a particular christmas night i had to stop in the emergency lane and manually clean the intake three times in a row...definitely not fun!
regards,
zp
  #28 (permalink)
Old 03-27-2008, 05:49 PM
Hi,
regards,
zp
Brisbane is considered subtropical so anything under 20C is considered cold weather.
Having lived in a cold place (-30C) I cannot imagine carburetted cars would be any fun at all under those conditions.
