#16 (permalink)
Old 02-22-2008, 04:03 PM
Sharky's Avatar
Sharky Sharky is offline
Hmmm, dunno if you guys have it by the same brand name, but we have Marley Drainflo and Draincoil. Light, flexible corrugated plastic tubing used for water works. Cant remember which is which, but one has perforations along its length while the other is solid. Comes in a variety of sizes from 90mm up to 160mm... Some retailers sell it by the coil (25m length) but some do sell by the meter.
Hope that helps
  #17 (permalink)
Old 02-23-2008, 04:25 AM
900 series's Avatar
900 series 900 series is offline
Originally Posted by 77SudTi View Post
Does anyone in Australia know where I can get lengths of that flexible hose that people use for cold air intakes and brake ducts? Never seen it anywhere, except maybe in a part store for a rediculous price!
When I was in Germany, you could buy this really great clothes dryer ducting by the metre off a reel, I should have bought some! So flexible, light and never wanted to collapse.
My dad got some the other day it was plastic with a metal coil through it. im not sure where he got it though, i'd recoment trying a couple of auto stores like Scotts auto 1, Supercrap(cheap) Auto, Autobarn...just have a look around and ask them about it.
Driving:1985 Alfa 33 1.5 4x4 Wagon
In the Shed..waiting: Alfasud Sprint
  #18 (permalink)
Old 02-23-2008, 11:07 AM
Greek Greek is offline
I have a crazey idea. I am thinking of cutting the metal top of the original airbox and place a couple of good pc fans connected somehow with 12v. This will increase thai air pressure in the box and maybe i can redirect air from the fron of the car onto thos funs so that they would suck ghot from engine bay. I have few good fans from decommsionnde server with very good air flow and i will try them in the future...
Sprint 1.5 '86
www.alfisti.gr
  #19 (permalink)
Old 02-23-2008, 11:30 AM
Alfam's Avatar
Alfam Alfam is offline
Hi,
With that, you will bypass the air filter, which is not good.
Cheers...
" Its like a Ferrari but a LOT less money "
  #20 (permalink)
Old 02-23-2008, 12:29 PM
i will aply filter most propably before fans...
Sprint 1.5 '86
www.alfisti.gr
  #21 (permalink)
Old 02-23-2008, 07:18 PM
900 series's Avatar
Since you drive a sprint why dont you take out both inside headlights and run a twin cold air intake from you new holes.
  #22 (permalink)
Old 02-23-2008, 08:25 PM
77SudTi's Avatar
77SudTi 77SudTi is offline
Would you be able to ask him where he got it? Ive tried places like supercrap, but its damn expensive and the drainage pipe isnt pliable enough.
Not sure about the legalities of not having high beams, also could get annoying when you want more light on those dark streets.
- '77 Sud Ti - Project car - C pillar "Ti" stickers needed!!
- '88 series II 33 1.7 Weber'd - More mint than yours!
  #23 (permalink)
Old 02-24-2008, 02:12 AM
evilgidget's Avatar
evilgidget evilgidget is offline
Send a message via ICQ to evilgidget
The stuff you're describing is called TPR ducting. You can get it from Clark Rubber (australia) or Para Rubber (NZ). They should be able to order it in if they don't have the correct size in stock (Comes between 50mm up to about 300mm from memory).
Other places around the world i'm not too sure on...
  #24 (permalink)
Old 02-24-2008, 02:15 AM
lenus's Avatar
lenus lenus is offline
My first sud had h4 low/hi beams in the outer lenses as well as h1's in the middle.
Maybe a 5.25" h4 lense is the answer?
  #25 (permalink)
Old 02-24-2008, 08:41 PM
Alfam's Avatar
I agree. The same.
  #26 (permalink)
Old 02-25-2008, 05:46 AM
cameron cameron is offline
Send a message via MSN to cameron
piping
i used to work in a plumbing shop thats where i got mine any k&r plumbing supplier will have some or know where to get it i later changed to the air conditioning duct as it is easyer to menouver in and out of places but it isnt as strong and it with stands some of the heat but try not to place any intake pipe near any heat if you do whats the point of cold air. my 0,02c
Over the hills and far away my ALFA ROMEO comes to play
  #27 (permalink)
Old 02-25-2008, 01:23 PM
Sudsonic Sudsonic is offline
Don't know if anyone remembers it ( probably not, it's jap afterall ) Years ago Suzuki had a swift model which had a belt driven fan at the front of the air intake to increase power...don't know how well it worked but I would think the boxer layout would leave room for a similar contraption. It worked like a mega cheapo supercharger.
1975 Alfasud Series 1Ti white ( only 24K )
1983 Alfasud Series 3 Green Cloverleaf red.
  #28 (permalink)
Old 02-25-2008, 03:21 PM
greku's Avatar
greku greku is offline
i heard about something like it from my local tuning shop, i searched on ebay and what i found was an induction kit that inside it's duct there is like a ''turbine'' that increases the suction...
  #29 (permalink)
Old 02-25-2008, 05:06 PM
RGC33 RGC33 is offline
I have also toyed with this decision> I decided that I liked the sound of the carbi induction noise. I removed the airbox and replaced it with foam pod filters on each carbi inlet. I think this actualy lost power in ordinary driving, it seemed to lose talk below 4,000RPM, but above 4 it sounded amazing and went alright too. In traffic in summer I had overheating problems, it just sucked to much hot air, but in winter driving in the mountains (about -5) it went like a little demon. So in the end sounded grate but didn't improve performance.
  #30 (permalink)
Old 02-26-2008, 02:53 AM
The best solution for that setup is to bring tubes directly on the filters redirecting the original path and creating 2 separeates tubes for each one or modifying the hood just after the headlights and placing 2 scoops for air like evo. In the seconf setup i dont know whats the case in rain and incoming water but this would be the best solution for me. I only have to find a second hood to make ths mod...
Sprint 1.5 '86
www.alfisti.gr
