Old 01-13-2008, 06:53 PM
lenus's Avatar
lenus lenus is offline
New Project Alfa. Yew.
So.. I've obtained a sprint and I had a spare 1.7ie engine laying around, and some spare 40's on a cactus 1.7ti engine.
So now we have the bastard child...
But I need some parts that I can't seem to obtain..
Does anybody have a spare set of flutes and airbox ???
Old 01-14-2008, 12:41 AM
alfasprinter's Avatar
alfasprinter alfasprinter is offline
Send a message via MSN to alfasprinter
nice sprint, hope you lower it to a better high though. sprint veloces come with a comical ride height factory. i have a set of horns and airbox but its in new zealand.
1981 Alfasud sprint veloce 16v race car yellow
1990 alfa 33 1.5ti series 2 champagne 1989 Alfa 164 3.0 v6 manual
Old 01-14-2008, 12:53 AM
jol's Avatar
jol jol is offline
Me too but in Sweden
Peter Strandberg
164 3.0 -89, 33 Sw 4x4 -89
Old 01-14-2008, 12:57 AM
lenus's Avatar
I agree! The ride height is comical, but even next to my sud, which is pretty low, the roofline still manages to be lower??
I've never had much to do with sprints before this one because I thought they were ugly, but after spending some time with it, I see why people like them. It really is just a better quality car then any alfasud.
Old 01-14-2008, 02:03 AM
BigSud's Avatar
BigSud BigSud is offline
Ugly? A Sprint?
I've always regarded them as one of the most perfectly proportioned cars ever made - try to find a bad angle on one! Even Guigiaro agrees, it's one of his favourites.
Old 01-14-2008, 02:10 AM
lenus's Avatar
Haha, I just never liked the back or the front - the side profile though is just perfect.
Old 01-14-2008, 02:30 AM
the roofline is a good 15cm lower than a sud. from the jacking points to the roof
Old 01-14-2008, 04:33 AM
GTVnut GTVnut is offline
Send a message via Yahoo to GTVnut
Yes the sprint is definitely made better, its really a classic 80's coupe, to me the sud looks a tad more modern though, more rounded at the front and more 90's 'hot hatch style', I'm thinking Daewoo Cielo and Holden Astra. After lowering my sprint, the handling was awesome, much better than my sud.... you say potato, I say potatoe? I can't make up my mind which one I like better............!
1982 Red Alfetta GTV 2.0 Litre
Lowered, Koni Shocks, tints, zender body kit, recaro seats, stock 15" wheels
1981 Sprint Veloce
1981 Sud Ti 1.5
1997 Daihatsu Charade- Boring Reliability
Old 01-14-2008, 04:39 PM
Lenus have you got any insights and tips for dropping engines and re-installing? Seems you have done a few already. What are your tried and true methods and what is the best way to remove those hex head bolts from the brake hubs at the front? Cheers.
1981 Sprint Veloce
1981 Sud Ti 1.5
Old 01-14-2008, 05:15 PM
81Sprint 81Sprint is offline
I've found the best way is to get a 6mm allen key impact socket, attatch it to a very long extension (or connect 2 toghter looks stupid but it works)
Remve the wheel.
Undo them with an impact wrench.
Old 01-14-2008, 07:26 PM
900 series's Avatar
900 series 900 series is offline
nice work on getting a sprint! we have many parts for the sprint that we were given..i'll ask dad when he's home tonight.
Generally i have noticed that our sprints roofline is a heap lower than all the other small alfas we own, just by sitting in them its really easy to tell.
To un-do those 6mm allens we crack them with a bar and the use an air rachet to get them out. if you dont own an air rachet i would recomend buying 3/4" socket 6mm allen from tool shop.
Old 01-14-2008, 09:20 PM
lenus's Avatar
Remve the wheel.
I actually do exactly what 81 sprint suggested except I don't have an impact wrench, I just use a 1/2" ratchet, and a torque bar to tighten them back up.
I think 3/4" is a bit of overkill.
I also have a normal allen key that I bought that is made out of the same stuff as the impact 6mm socket thing, it's very strong, it's also very good at undoing those as it has a really long arm thing??
I know what I'm talking about.. The allen key is just big. But yeah.. Extension bars ftw. Turns what used to be a 1 hour job into something like 5 minutes for both sides.
lenus.
Old 01-14-2008, 09:54 PM
Cool, thats just the advice I needed. Do you remove the handbrake cable and let it hang? What about the gearstick lever?
1981 Sprint Veloce
1981 Sud Ti 1.5
  #14 (permalink)
Old 01-14-2008, 10:15 PM
lenus's Avatar
Normally I undo the cable at the brake caliper, but this time I undid the cable inside the car so I didn't have to reconnect it at the brake calipers..
And the gearstick lever... ?? That stays on the box, but I take all the boots and knob off before dropping the engine.
I've got a neat little trolley that I use to put the engine on, it's really just a fridge trolley, and the other one I have for when the engine is out is the base of a really hardcore filing cabinet.
I generally get enough clearance to clear the gearstick lever so I don't have to remove it.
I take out the cross member first on the jacks, then lower the car down onto what ever trolley I use, so that the engine weight is taken by the trolley, then I undo the engine mounts and jack the body back up so the main mount is clear of the body.
Then I put a bolt through that mount, and hook up the endless chain and crank it up...
IT looks dodgy, but it's far less dodgy then balancing jacks ontop of wood
  #15 (permalink)
Old 01-14-2008, 10:46 PM
900 series's Avatar
whoops i meant 1/4".
