01-12-2008, 09:51 AM
How to remove (or turn) oil vapor separator
Hi all
I'm in the progress of putting a 1.5 into my 33 to keep it running during the winter, while I restore the 1.7ie.
I've moved all the injection and everything, except the oil vapor separator. It points forward on the 1.5 and to the right on the 1.7. I need it to point right to clear the plenum but it's not being very cooperative.
I suppose it's just pressed down, but when I tried to lift or turn it with a plier it just got dented.
a pic of the 1.7
Alfapower - Galleri :: Motorbyte hit och dit :: DSC01030
Peter Strandberg
164 3.0 -89, 33 Sw 4x4 -89
01-12-2008, 12:24 PM
If I remember correctly the steel tube is press fitted into the aluminum bell housing. You need to heat up the aluminium around the tube and pull it out.
01-12-2008, 01:22 PM
Out with the torch then...
thanks
Peter Strandberg
01-12-2008, 11:51 PM
Is this an IE-type separator or a carburettored one? The IE version had a big "pod" on top of it which is held on with a screw - which you probably can't see because it's down inside (where you pour the oil). It may turn if you slack the screw off - I can't remember if it's keyed or not.
If it's a carby one, then yes, it may be that the only way is to use the torch - to cut it off and reweld it on pointing in the right direction. I only say that because I tried once to get one out of the aluminium rear cover casting and it did not go well. Not at all.
Good job I had a spare.
Chris
01-13-2008, 12:04 AM
It's the 1.5 straight tube one. I removed the fuelpump plate on the 1.7ie but saw nothing that would keep it into place, so I figured it would be the same on the 1.5.
As it's only a tube I could just aswell cut it of and weld it back, and If it breaks to scrap I'll lathe a new.
Peter Strandberg
01-13-2008, 10:40 PM
Yea it is keyed i have changed mine to point towards the front of the car, not to hard to make a new key in the new position.
Current Vehicles
- 1990 33 16v - Lots of mods mmmmm...
- 1983 Sud Ti - Race car, in the making!!
For sale ;
33 1.7 parts, bumpers, FRHS light, front quarters,
working speedo
01-14-2008, 12:17 AM
i was tinkering with my 16v engine for the sprint today and the whole tube pulled right out of the rear cover, doubt this is normal but it means i can rotate the whole lot towards the back of the car to make fitting a catch tank alot less cluttered.
1981 Alfasud sprint veloce 16v race car yellow
1990 alfa 33 1.5ti series 2 champagne 1989 Alfa 164 3.0 v6 manual
01-14-2008, 12:47 AM
Why is the gearbox attached to that engine a 4x4 box??
What sort of 1.7ie are you running!!!
*edit* I see that you are in Sweden, and I see that your car is a wagon, so it's probably standard over there for 4x4 wagons to have a 1.7ie
I'm jealous.
Reason: I'm blind.
01-14-2008, 01:01 AM
Here's the project thread, Swedish but you get the pics
AlfaPower - Dill & Gräslök, 33 Sportwagon 1,7ie 4x4 megasquirt kompressor - Powered by XMB
The car is now a 1.5ie, put the engine in yesterday. Just have to wire in the vacuum hoses and some electrical.
The vent outlet still points forward, it wouldn't move so I loosened the pulse damper/fuel pressure bracket to make it clear instead.
I'll have to add a elbow and some hose but it seemed a smaller project than heating it up, with all the injection being there and all.
Peter Strandberg
01-14-2008, 01:17 AM
I like the super charger
01-18-2008, 12:20 PM
I too like it  It seemed a piece of cake fitting it, without all fuel, vacuum and electrical there... ...and then I put the engine in the car... but it shouldnt be impossible
Here's a pic of how I did, no pipe was to find so I used a t-pipe and plugged the extra connection.
Peter Strandberg
