electrical fuel pump for carbs? - Alfa Romeo Bulletin Board & Forums
Old 10-24-2005, 10:58 AM
Dear all. What electrical fuel pump is reccommended for the 1.7 8VQV? Twin dellorttos. I think I am getting fuel starvation at high rpm at 4/5 gears. Car has cams.
4-5 psi? 6? I am looking at facet pump. Or anyone has one for sale. Thanks.
Old 10-24-2005, 11:36 AM
jackr's Avatar
Try the Carter 4070
http://www.racetep.com/webfuelspark.html#webfuel
Jack - '67 GT Junior
Old 10-24-2005, 06:50 PM
87Sprint's Avatar
if you are running carbs then it is a low pressure mechanical pump... you can buy electric low pressure replacements from stores such as www.international-auto.com are you sure the pump is the problem?
No more Alfa ..
Old 10-24-2005, 09:50 PM
Thanks guys. I actually faced the problem at 3rd gear initially. Had to ease the throttle a while and power resumed. Then I drilled out the banjos a little and it helped. Then the same problem occurred at 4th and fifth gear. All temp readings shot up.
Old 10-24-2005, 09:57 PM
Originally Posted by jackr
It sounds good. I am quite keen actually. Do you have any experiences to share. Right now I do have some symtoms the article mentioned. Thanks again for the input.
Old 10-25-2005, 05:26 AM
jackr's Avatar
I havent had experience with this pump...
although it sounds like the way to go. I've read a couple of posts on the Carter. I think Summit Racing has it for ~$60.
Old 10-25-2005, 06:52 AM
I might be buying. Will let you guys know the outcome. Thanks again.
Old 01-31-2006, 10:20 AM
No more problems to fuel feed now. Problem solved. Thanks guys. It really helped.
Old 01-31-2006, 11:18 AM
jackr's Avatar
Did you buy the Carter?..
Is it very noisy?
Old 02-01-2006, 09:41 AM
You're darn right it is. But after the problem with the fuel supply, I kindda feel more at ease to hear what's going on with the feed.
