Old 09-25-2005, 11:59 PM
33 Clutch?
Hello,
I was an Alfa virgin up until yesterday when I (foolishly?) bought a 33 1.7 QV. I drove it home alright but today when I tried to drive it I couldn't get it into gear. The clutch goes nearly all the way to the floor before it feels like it's doing anything but when I tried putting it in 1st or reverse it made a horrible graunching noise (heaps worse than the occasional 3rd to 2nd noise). On one attempt the car seemed to move forward a bit before I pulled it out. I tried pumping the clutch but it made no discernable difference.
Am I doing something wrong or is there something wrong with the car?
I searched this messageboard and Google but couldn't find a similar sounding problem.
Any help would be appreciated.
Old 09-26-2005, 12:32 AM
kaBOOM's Avatar
(foolishly?) bought a 33 1.7 QV <-- Never a foolish idea!!!!!
Sounds like a Clutch master/slave cylinder is not supplying enough pressure and the clutch is not dis-engageing totally (hence the crunch)
First I'd double check the amount of hydraulic/brake fluid you have. If thats toped up then you'll be looking at the cylinders. Good news is Clutch master/slave cylinders are quite easy to source, and if they are totally stuffed are not that expensive (Compared to say my VL turbo....) Worst case is that its the clutch pressure plate has packed up and snapped the "springs" (for want of a better word), I've seen it happen once.
Where abouts are you located?
Old 09-26-2005, 12:48 AM
Hi Kaboom
I'm in Auckland, NZ.
The fluid level seems fine. Howcome it was fine yesterday when I bought it and doesn't work now? 5 years of thrashing a 260,000 km Camira didn't brake anything, but 45 mins driving an Alfa...
Old 09-26-2005, 12:54 AM
kaBOOM's Avatar
Originally Posted by V8Pete
Hi Kaboom
lol, go the Camira, I'm working on putting JE Camira EFI on my Alfa motor They are quite a robust and quick car (Camiras) considering the horrid reputation they have......
Maybe some air go into the sucker......sit in the driveway, pump it two dozen times or so, and then try it. If its O.K then, well you have some air in the system, your local mechanic (or yourself) should be able to fix that in no time (at very little cost)
Old 09-26-2005, 01:02 AM
Camira's are great. I love mine but it smells terrible and I hate turning up to places smelling like the Camira so I thought I'd get an Alfa to see if they were all they're cracked up to be. Maybe I shouldn't have parked the Alfa in front of the Camira on the (uphill) driveway.
Give me a cable clutch any day
Old 09-26-2005, 01:15 AM
kaBOOM's Avatar
Uh cable clutch, I've had several run-ins with the damn things. Never again....lol
Old 09-26-2005, 12:24 PM
Hi,
Many moons ago, well 4 years, I had a 33 P4. AMongst all the other things I replaced in taking the mileage up to 250K was the clutch, similar failure to yours turned out the finger springs on the pressure plate had finally given up the ghost meaning it was impossible to release the pressure plate. Just for information on the P4 I replaced;
All the propshaft UJ's several times.
Wheel brgs Front & rear
Rear springs- they both cracked
Front suspension strut- the spring platfrom rusted through firing the road spring into the road!
Clutch
Clutch slave cylinder
Timing belts
Fuel tank
Finally gave up when the reinforcing plate that the viscous coupling ripped out the floor....
Apart from that a great car!
Old 09-27-2005, 12:44 AM
kaBOOM's Avatar
/me dreams of getting a P4......
Old 09-29-2005, 10:54 PM
Smile
I talked to the ex owner who said it had just had a new slave cylinder. I bled it today and it seems all good.
Old 10-08-2005, 01:01 AM
Grrrr
More air. Looks like I'll be attacking the master cylinder. I've spent more time working on it than I've spent driving it...
Old 10-08-2005, 11:50 AM
genius's Avatar
Pete...keep going...once it's good you'll have a great time...
PM me if you need directions to a good Alfa mechanic/parts...(I'm also in Auckland)...
88 75 3.0 (New QV cams!!)
Old 10-08-2005, 02:26 PM
It'll have to sit rusting until next weekend. It was too windy yesterday and today... am I allowed to mention Bathurst on here?
Old 10-12-2005, 03:46 AM
Genius, are master cylinder kits available for 33s? If so, where can I acquire one? I rang Racebrakes and they can only reco it for $125.
I haven't pulled it out yet - just asking in advance.
  #14 (permalink)
Old 10-12-2005, 04:39 AM
evilgidget's Avatar
Send a message via ICQ to evilgidget
Why reco when a NEW one is only about $195?
  #15 (permalink)
Old 10-12-2005, 06:14 PM
Don't know why I didn't think of it earlier, but CCS has a kit for $47 or new for $136. Problem solved.
