Old 06-11-2009, 08:59 AM
KACK's Avatar
KACK KACK is offline
16v conversion
Hi All ,
I have a 85 33 and am planning on transplanting a 1.7 16v injected motor into it for doing some hillclims and sprints
was after any pointers, tips or probs anyone has come across performing this transplant.
will it mate up to the existing gearbox?
I also have the power steering out of the doner vehicle, will this fit?,
Has anyone lightened the flywheel, if so by how much
any help would be appreciated
cheers
Old 06-11-2009, 04:36 PM
budweiser_sud budweiser_sud is offline
Interesting project - my thinking would be that if you are preparing a 33 for hill climbing and you want a 16v engine, it might be more cost effective to buy a 16v 33
But, this is what this list is all about!
I would say as long as you can get a hold of a complete 16v engine with all the throttle bodies, loom, ecu, sensors etc you are pretty well good to go to drop it right in. It will mate to your existing gearbox. If you are getting your flywheel lightened, it would make sense to rebuild the engine and have this done so it is balance with the crank shaft and clutch assembly. Rebuilding a 16v engine doesn't have to be expensive - you won't need to replace pistons or rods if its been looked after.
The complexity will be wiring it in, but if you have all the bits just be thorough and take your time to connect everything up.
Good luck
~Benjamin
[FONT="Comic Sans MS"][U]Daily Drivers[/U][/FONT]
-'91 Alfa 33 series 3 16v
-'90 Alfa 164 3L 12V
[U]Projects[/U]
-'82 Alfasud Ti mid-engine Alfa V6 project coming soon!
[U]For Sale[/U]
-'82 Alfetta Sedan - in bits, take me, I'm free!
Old 06-11-2009, 10:11 PM
lenus's Avatar
lenus lenus is offline
I agree with the bud, it would probably be cheaper and easier to use the 16v 33 instead of transplanting.
IMHO, the older shape 33 doesn't really have much benefit compared to the 16v. I'm pretty sure the difference in weight is because of the extra things in the 16v like power-steering and aircon and the heavier 16v engine. So if you are thinking of doing this because the older 33 will be lighter, you might want to reconsider!
A sud or a sprint will, however, be lighter.
And I can't speak for the 33, but when I tried to fit the power steering to my sud, I found that the splines that connect the steering column were different to that on the steering rack. So while it would be possible by changing those splines - it wasn't a direct fit for me.
The engine will go straight in though, but you will need the 16v crossmember.
Hope I was helpful for you!
Cheers.
Old 06-11-2009, 11:35 PM
dave33's Avatar
dave33 dave33 is offline
Been there, done that. I had an 89 S2 car set up for racing and didn't want to start preparing another shell all over again. A Sud would probably be a bit lighter, but I was keen to continue developing the 33. Spares are lots easier to get !
The fuel lines and fuel tank are different, moved them over from a donor car, also the electric fuel pump needs fitting, also the fuel filter in the engine bay. Front cross member has already been mentioned.
The wiring is reasonably straight forward if you work logically through it, although there's plenty of it !
Your current g/box will fit but you will need to grind a little semicircle in the bellhousing to accommodate the crank angle sensor.
Please budget on new cambelts and pulleys if needed !!
If you have a 16v with powersteer and aircon, the crank pulley extends too far out in front, and needs modification or replacement with a custom made item or it will foul the radiator.
Also the radiator fan is a challenge - bugger all room to fit it in there, so I ended up finding a non-Alfa one and fitted it to the outside, modifying the grill & bumper slightly (but unnoticeable from the outside.)
You'l need to transfer the exhaust system too.
If it's for competition, forget the power steering IMHO. It is adding weight and dragging power from the motor - why would you do that ?
I also grafted in the bracing pieces from the fire wall to the chassis rail on each side of the engine bay. The S2 33s are prone to cracking on the inner guards and the chassis rails over time. Worth doing, although its a fiddly job as the fire wall isn't dead square on the S2 like the suds & S3 cars are.
That's the bad news, the good news is that the 16v is a good bit quicker than the 8v 1.7 in stock trim. Took 1.5sec off my previous best lap time at Pukekohe race circuit, with the set-uo otherwise the same. It runs sharp and clean, but is a ***** to change the spark plugs on, although I haven't had to yet. Has a rev limiter at around 7K rpm I have found too. :-)
Best of luck, it's a bit of a job, but very do-able.
Happy to assist further if I can.
David F
p.s. I haven't tried playing with lightening the flywheel yet...
1989 Alfa 33 1.7 QV (x 2)
1 for the road 1 for the track
Old 06-11-2009, 11:43 PM
KACK's Avatar
Lenus,
Would use a 16v 33 if i could find one over here.
Only sprint/sud ive seen for sale over here in the last six months had rust holes that i could fit my head through.
I had my 33 already, then the 16v engine became available in a written of car from the adelaide..
Not sure about the power steering, got given it with the rest of the parts, its just a thought at the moment.
cheers
Old 06-11-2009, 11:54 PM
veloce sprint's Avatar
veloce sprint veloce sprint is offline
the double skinned firewall also needs modification to fit a power steer rack , it is not a bolt in job ,
alfa romeo trofeo series new zealand, video site .
http://alfa-racing.blip.tv/
Old 06-11-2009, 11:56 PM
dave33's Avatar
Did I get it right otherwise ?
Old 06-12-2009, 12:06 AM
pretty much smack on i recon Dave , suppose we could mention not to just machine off the air con groove in the front pulley as the thing will come apart shortly after , like a stage of the targa or some other most inconvenient time ... ay Chris..
Old 06-12-2009, 01:00 AM
dave33's Avatar
Yeah, I got a nice custom turned ally job just like Eds one !!
Old 06-12-2009, 02:13 AM
lenus's Avatar
those pulleys' come off?!:!!|SAQD
Old 06-12-2009, 02:19 AM
KACK's Avatar
[quote=dave33;758187]Been there, done that. I had an 89 S2 car set up for racing and didn't want to start preparing another shell all over again. A Sud would probably be a bit lighter, but I was keen to continue developing the 33. Spares are lots easier to get !
This my logic as well, i already have the car and engine so i might as well use it
i dont have a donor car so fuel setup might have to be custom
what about the clutch, are they the same?
I will do this before fitting the engine to the vehicle, might make things a bit easier me thinks
gotta find one first
David F
I will be asking plenty of questions
Old 06-12-2009, 02:25 AM
dave33's Avatar
Pretty sure the clutch was the same on both the 8v and 16v that I had.
The 16v engine is a development of the older engine so there is a fair bit of commonality.
There are some interesting features on the 16v, like the fact that the fuel pump only runs when the engine is turning (crank angle sensor needs to tell the ECU to turn on the fuel pump) Need to make sure the wiring is done correctly or it won't run - found that out... :-)
Cheers
David
Old 06-12-2009, 03:06 AM
alfettaGTAm's Avatar
alfettaGTAm alfettaGTAm is offline
That's nice to know. i'm about to put a 16v in my Sprint and was going to have my mechanic cut one of the grooves off (I want to keep two so that I have one for an attempt to fit air con).
Any idea where to get a custom one?
Christchurch, NZ. 92 164QV; 87 Sud Sprint (16v project); 80 Sud (Race car); 77 Alfetta GT (Long term project - A & m would be nice); (Plus a 164, 75 and two 33 parts cars)
  #14 (permalink)
Old 06-12-2009, 04:02 AM
dave33's Avatar
I found a nice tame engineering firm on the North Shore in Auckland.
If you took the original to a good engineer it's doable.
The original is terribly heavy too !
The originals have a layer of rubber between the inner and outer steel parts of the pulley. Not great if it comes apart !
  #15 (permalink)
Old 06-15-2009, 09:06 PM
KACK's Avatar
BTW, does anyone know the size of the nut that secures the harmonic balancer?
