#16 (permalink)
Old 07-20-2009, 02:10 AM
MarkP's Avatar
This will fit that leg. Tony from Lucente Motors in Baywater redrilled my rotors. Ph 9271 1355.
  #17 (permalink)
Old 07-20-2009, 02:59 AM
KACK's Avatar
cheers mark,
Are you experienced?
  #18 (permalink)
Old 09-02-2009, 09:29 PM
Send a message via MSN to cameron
to all the vl turbo/vn v8/vp/vr commodore calipers may all be the same only thing is the bore dia i have the vr callipers on a deawoo nubria cross drilled and slotted disc(filed the stud holes a little) all that is needed is a washer between the calliper and the hub mounting surface standard bolts are still used. with the flap wheel on the grinder they fitt under a 14'' wheel and performance is 110% better
Over the hills and far away my [B]ALFA ROMEO[/B] comes to play
  #19 (permalink)
Old 11-03-2009, 02:42 AM
i dont know a lot about specs of modifications, but i bought a 1991 33 16v a week or 2 ago, among other mods it is an awsome car & handles great......but in relation to your post mine is running ventilated front discs with VT commadore calipers ( mind you it has 17 inch rims / low profiles ( 205/40/17 ) which i have road leagal certificate for, in australia. just for any ideas if it helps
