Motor nach Parameter
This is Mahle catalog, you can try your luck there. As as far as i can see right now, SR20 engines use 86 mm bore and piston pin is 22mm in diameter, so i don't see hou to use them in 1.7
as for nissan, KA24DE pistons are almost the same as Alfa's: 21 mm pin, 89 mm bore, almost equal total piston length, and 1 mm less compression height
