Is the axle that different between the disc and drum setup? ... would the shock still fit (Koni that is), ie. just use it on the old axle? OR go to a Koni shop, they will adapt it for you. All Konis can be modified and adjusted to suit.
I made the same mistake with my Sud many years ago and replaced ALL bushes with those horrible (my opinion
) neoprene bushes and thus effectively locked up the rear suspension. The car was as nervous as afterwards ... but I was too distracted in other areas to change back.
On the track you want hard (spring rate) rear suspension ... but you still want movement ... Bilstein shocks have always been way too hard, unless you are into rallying.
