Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Boxer Engined Alfa Romeos
  #46 (permalink)
Old 12-21-2008, 06:26 PM
mximus mximus is offline
Trying to get the rev counter to work at the moment (was going to wait and get the hard rev limiter but didn't bother in the end) but the documentation is a bit confusing. Does it get wired into the EDIS or MJLJ? Also there are 2 pairs of wires coming from the rev counter (blue & purple) which i suspect one pair is the correct one, anyone have a picture or something so i can identify which one is which?
ps Once I have done some tweaking on the map i'll post my configuration.
[edit] also unrelated, when i started her up this morning the choke light stays on even when it is pushed fully in, it also only comes out about 1cm...seems to be jammed (i was never able to pull it out much further but i didn't fix it since i never needed to use the choke), anyone else had this problem?
  #47 (permalink)
Old 12-26-2008, 04:52 AM
baldy baldy is offline
Hi ,its one of the smaller wires that went to the coil.and its wired to the mjlj unit not the edis. hope this helps
  #48 (permalink)
Old 12-26-2008, 02:18 PM
Greek Greek is offline
Dont worry it is most common problem. Mine has the same attitude.
Sprint 1.5 '86
[url]www.alfisti.gr[/url]
  #49 (permalink)
Old 04-13-2009, 09:44 AM
cameron cameron is offline
Send a message via MSN to cameron
damn i think that i will be starting to modify my 33 a bit more any one know where i can get a megajolt system from
Over the hills and far away my [B]ALFA ROMEO[/B] comes to play
  #50 (permalink)
Old 04-16-2009, 09:59 PM
will this kit work with the edis
Programmable High Energy Ignition System - Jaycar Electronics
are there any programable ignition only ecu's out there
  #51 (permalink)
Old 05-29-2009, 02:58 AM
ok i have just bought a mega squirt v3.0 and everything but the guy i bought it of isnt runing a modul straight from the mega jolt all that is needed is plugs tps and installing the system
