Go Back   Alfa Romeo Bulletin Board & Forums > Alfa Romeo Technical Forums > Boxer Engined Alfa Romeos
  #31 (permalink)
Old 09-21-2008, 07:21 AM
33gold's Avatar
33gold 33gold is offline
Hi Baldy, all up and running; tried to recreate a map from the 1.7 manual, ran ok but was a bit dissapointed. Downloaded a dyno tuned 1.8 ford zetec map from mj forums just to see what it would do, took it out today. I have created a monstor!!!!
Issue now is that the 1.7i.e. clutch that I fitted (brand new) now slips when I go into second (probably slips in 1st but so much wheel spin i cannot tell). Am getting some Yokohama A048's this week which will make it worse. I am changing gear at 8000 rpm at present and she wants to keep going, but with std rods etc just lightend I am nervous. I have never had a car that revs so freely (and I had a chipped Fiat 20v Turbo). I get to 2nd gear 8000rpm in about 6 seconds from standing start. Glad I put 16v discs and calipers on plus braided stainless hoses. will polish and post some pics next week.
Current: Alfa 33 MK1 Hillclimb project, 1971 Fiat 124AC. Previous:Fiat Abarth 130TC (x2), 131 Racing, Chipped Fiat Coupe 20v Turbo (what a car).
  #32 (permalink)
Old 09-29-2008, 06:51 AM
33gold's Avatar
Some pics of the installation:
  #33 (permalink)
Old 09-29-2008, 06:56 AM
33gold's Avatar
and some more
  #34 (permalink)
Old 10-29-2008, 05:53 PM
mximus mximus is offline
I have collected all the components necessary to start installing...just the Throttle Position Sensor is missing. Anyone know which TPS is recommended to use?
  #35 (permalink)
Old 10-30-2008, 05:26 AM
33gold's Avatar
Mine is a wabash 971-002, got it via triggerwheels.com the first failed after 2 months, was replaced by Chris no questions great service. this tps fits nicely after welding an extension onto the end of the throttle mechanism; I used an allen key.
  #36 (permalink)
Old 11-26-2008, 02:14 PM
I am almost half way through the installation, just a quick question. Did you guys use the temperature sensor (to correct advance on warmup) on yours? I wasn't sure if it is that important since it doesn't get too cold here.
  #37 (permalink)
Old 11-26-2008, 04:22 PM
33gold's Avatar
I haven't go the temp sensor on mine, runs great in Perth (never goes below 16 degrees in the day in winter).
  #38 (permalink)
Old 11-29-2008, 12:57 AM
76Alfasud5M 76Alfasud5M is offline
Regarding MAP sensor vs. TPS: I'm in the process of installing a system from Simple Digital Systems EM-4 on my 1.7l 16V boxer. It uses throttle bodies and the initial setup wouldn't work correctly due to dramatically fluctuating vacuum. Their recommendation was to add a cylinder of air as big as a coke can for all 4 vacuum lines to terminate at in order to smooth out the vacuum.
Will this even work? Or is the 16V boxer impossible to get steady vacuum? I know it's possible to go to a TPS system but I've been told this can be a good idea for a race car, but lousy on the street, particularly at low rpm.
Any ideas??
  #39 (permalink)
Old 11-29-2008, 05:14 AM
jol's Avatar
jol jol is offline
Yes it will work, and a a carb fuel filter inline will also help to flatten out the map signal. TPS, correctly mapped, will work on both race and street (but harder to tune than map, assuming map is doable)
Peter Strandberg
164 3.0 -89, 33 Sw 4x4 -89
  #40 (permalink)
Old 11-29-2008, 08:29 AM
33gold's Avatar
It's all about the cams I believe with MAP, as long duration cams fluctuate the vacuum as they overlap so much. The TPS installed on the end of the throttle shaft is a neat solution, not sure why you would go for MAP. Having said that mine isn't a street driver so....
  #41 (permalink)
Old 12-13-2008, 03:09 PM
baldy baldy is offline
new tps
Hi, i scrapped my old tps idea,not because it did not work i just didnt like the look of it and will be installing this newly made one once the engine is all back together, i thought i would post a few pictures to show how i did it
  #42 (permalink)
Old 12-14-2008, 08:39 PM
33gold's Avatar
Nice and neat this setup works well on my 33.
Just bought a 1971 Fiat 124 Convertible to restore so not sure how much attention the 33 will get other than fixing race problems.
  #43 (permalink)
Old 12-14-2008, 08:51 PM
Finished the setup and got everything running, is the default map good enough or does it pay to tweak it a bit? (haven't had time to play with that side of things yet).
  #44 (permalink)
Old 12-14-2008, 08:53 PM
33gold's Avatar
Factory default is a good starting point, mine is fairly modified so I have a very steep advance curve, the default worked OK though.
  #45 (permalink)
Old 12-15-2008, 08:32 AM
maps
seeing as we are all using tps , why dont we post our maps to compare results what works and what does not !!! just a thought
