Double Flaring Brake Pipes
My 105 GTV2000 brake pressure reducing valve had corrosion so I decided to purchase an adjustable one from Alfaholics who said that it came with new fittings that just needed new double flared ends fitted to my pipe work.
Purchased a double flaring tool and then tried 4 times to get the tool to create a proper flare. It does not seem to be working, either the tool is not good enough for these steel brake pipes or it is me??? I had done this job many years ago but that was on a trailer brake system with copper tubing. It should not be that hard, it seems to create the flare on an angle.
I was wondering if anyone who has done this job can advise me on what Double Flare tool they used that worked, so that I may try to get one here in Perth, and any other tips would be appreciated.
Super1600 I have sent you a PM on this.
Regards
Tim
