Does the 'temporary memory'... - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 11-20-2011, 07:15 PM Thread Starter
Biba69's Avatar
...on a receiver/head unit always require power? I assume that it does. And going on that basis, if someone needs to remove the battery, will attaching the cables from a battery charger to the +/- cables suffice to keep the memory, umm, memorizing? I'll add that my charger is ancient but works well for basic charging.
Could it do damage, especially to a new receiver with add-ons which I assume will have numerous specific preference settings?
Actually I'm planning on getting a Harbor Freight battery jump starter which would probably work better for this.
To make it clear, the receiver would not be turned on.
Comments?
Biba
AlfaCyberSite.com
BibaRestorations.com
Biba69 is offline
post #2 of 5 (permalink) Old 11-20-2011, 07:44 PM
bshorey's Avatar
Send a message via AIM to bshorey Send a message via MSN to bshorey Send a message via Yahoo to bshorey
Comments?
If you don't want to lose what's stored there, some do, some don't. If you are worried about such things as security codes and what not, then yes, you need to keep power to the unit.
A charger should work fine. Just be careful when you disconnect the battery to not let the POS lead touch the chassis.
bs
bshorey is offline
post #3 of 5 (permalink) Old 11-20-2011, 08:21 PM
Gubi's Avatar
Mmm...I'm not sure if I'd use a charger for that application. I don't think a modern charger would even work: they base the charge rate off battery voltage, so if they don't sense a battery there they won't put out any volts.
They sell small battery powered devices that plug into the lighter socket to maintain the battery during service. Here's one for $8:
http://www.amazon.com/Computer-Memor.../dp/B000J4HHVM
1991 Spider
Gubi is online now
post #4 of 5 (permalink) Old 09-26-2013, 03:23 PM
JJordan's Avatar
Old thread, but you can just alligator clip a 9V battery to the battery terminals, watch the polarity. That is enough to retain the memory while changing the car's battery.
JJordan is offline
post #5 of 5 (permalink) Old 05-10-2014, 06:40 PM
Nakagtv's Avatar
Has anyone tried battery backup system that car alarm systems use? Basically its a rechargeable battery that keeps security system on in case thief disconnects terminals from car's battery. I am thinking about using this for car's stereo unswitched power and maybe for a gps tracking module... Any ideas?
https://www.google.com/search?q=back...battery+system
Zaza
Refreshing 1970 Euro-spec GTV 1750
Nakagtv is offline
Replace with
